1978 - 1996 Big Bronco
'78 track bar bushing
Old Jun 18, 2006 | 11:01 AM
bpete's Avatar
bpete
'78 Bronco repalced all bushings with polyurethane(c bush, radius bush, track bar) & now the upper/frame mount (LH side) bushing keeps going out. Parts seem to fit snug when installed new. bushing snug in bar end, bolt snug in hole. I tighten the bolt up snug but not excessively tight. bushing is only lasting about 3,000 miles. Bronco has 2" lift now & I installed 6* C bushings planning for a larger lift in the near future. could too much caster be the culpret? Has anyone else had this problem? Thank You
Old Jun 21, 2006 | 04:05 PM
jonnybronco's Avatar
jonnybronco
I would say it could be due to too much caster. A 6* bushing is typically used for a 6" lift, that would be excessive for just 1" of lift.
