1978 - 1996 Big Bronco
Messed up the steering column
Old Jun 18, 2006 | 01:08 AM
siphor84's Avatar
siphor84
recently when i took off the steering wheel i somehow managed to misalign my pulling tool such that when i cranked on it i was pulling upward on the column (dont ask me how i did this, it was late and i dont even remember anymore )
since then there has been a little bit of play in the steering wheel, not rotational but rather a back-and-forth play that allows me to nudge the wheel up and down. i more or less dismissed it and figured i'd fix it some day. I'm now having a new problem where when I turn the wheel left and right, it shorts something and blows my turn signal fuse. I can't help but think this extra play in the steering wheel is allowing it to pinch something in the turn signal switch.
so the question(s): how concerned should I be about the stress i put on the column, and do you think this back-and-forth play could be the cause of my electrical short?
thanks,
robert
1988 Bronco XLT, 5.8
Old Jun 18, 2006 | 09:05 AM
RanchRodsTX's Avatar
RanchRodsTX
You might have stretched the wiring harness where it attaches to the column sleeve. The could be the source of your short. See how tight the harness is at the trip plate that will tell you.
Old Jun 19, 2006 | 01:35 AM
siphor84's Avatar
siphor84
Harness seems to be OK. While reading more I'm becoming more suspect of the steering shaft, so I'm going to pursue that avenue for a bit. Thanks for the input.
Old Jun 19, 2006 | 08:47 PM
siphor84's Avatar
siphor84
Alright, some more information:
The short is occuring because the steering wheel is sitting too low into the column housing. It is rubbing against the outer edges of the housing and grooving it, at the same time it is touching electrical contacts on the turn switch assembly.
I can pull the steering shaft in and out about 1/8 to 3/16", it seems that this slack is what is allowing the steering wheel to sit so low. Is this slack normal? This slack makes me worry that something is really wrong with the joints in the shaft. What are your thoughts on this?
