Hot starting problem
Old Aug 11, 2001 | 09:21 AM
69f250mg's Avatar
69f250mg
Help, when my truck is cold it starts fine, but when it warms up (10-15 minutes) the starter drags like the battery is very low. I replaced the starter and wrapped it, tried a different battery, and checked the battery connections. Nothing helped; any ideas?
Old Aug 11, 2001 | 10:05 AM
6t6merc's Avatar
6t6merc
Did you clean and tighten the ground strap?
Eric
Old Aug 11, 2001 | 03:16 PM
ksd's Avatar
ksd
I've got the same problem. New battery, and she fires up right away when cold, even after sitting for a week without moving. When hot, though, it barely turns over.
ksd
69 F100 Explorer lwb 2wd FE 360 C6. WANTED: straight/clean styleside long box w/aux fuel tank for 67-69 F series.
Old Aug 11, 2001 | 07:32 PM
Doop76's Avatar
Doop76
My 76 has the same problem -- has new battery, starter, and wires. I wish someone would tell us what it is!
Doop <
76 F-100 Custom (96K Original North Dakota miles) 360-C6 All stock
64 F-250 (Bought from the north slope of Alaska) 292-T18 4 speed
Old Aug 11, 2001 | 07:53 PM
Franklin2's Avatar
Franklin2
Set the timing back a little, till the problem goes away.
Old Aug 11, 2001 | 11:17 PM
69f250mg's Avatar
69f250mg
I replaced the groud stap from battery to frame and it did not help so I added a ground from the engine block to the frame and this improved the starting. Although some times it still takes 2 or 3 tries to get it going.
Old Aug 12, 2001 | 11:41 AM
jwtimme's Avatar
jwtimme
sounds like the starter is getting to hot. Are you running headers, they will heat the starter because they are closer then the stock exaust. Also how close it the exaust pipe to the starter. I had the same problem, The muffler shop bend the pipe wrong and got it too close to the starter. I'm also running a set of 406 exaust manifolds that offer much better flow than stock. try putting a starter heat shield on the starter and see if that helps.
Old Aug 13, 2001 | 01:02 AM
Gai's Avatar
Gai
i had the same problem on my 73 f-250.
as soon as i put the timing on 10 the problem
stop.
Good luck,
Gai.
Old Aug 13, 2001 | 02:47 AM
BigBrownTruck's Avatar
BigBrownTruck
How about also making sure the surface that the starter meets the bellhouseing is clean and oil free too, that's a ground for the starter as well.
BBT
Old Aug 15, 2001 | 08:49 AM
bigricker's Avatar
bigricker
common problem it seems, as i had the same with a 69 F100 with a six banger. Went through all the same things, battery, connections, etc... But the problem turned out to be my fan belt was loose and the when the motor got hot the valves got stuck. Not hot enough for the gauge to get high, but once I tightned the belt, the problem went away. Worth a try anyway. Maybe new belts, too?
Old Sep 5, 2001 | 01:17 AM
Boomer95's Avatar
Boomer95
Electronic ignition module??
Old Sep 5, 2001 | 01:37 AM
mldisibio's Avatar
mldisibio
had the same on my 68 390, although the 'dead battery' thing didn't happen every time- mostly just hard starting when hot;
no expert here, but one problem was the carb flooding, also a gasket leak behind the carb; after both problems were fixed, it starts up fine when hot;
also, doesn't this happen when the fuel to the carb evaporates after absorbing the heat from the manifold, but corrected with a spacer under the carb?
Old Sep 5, 2001 | 05:17 AM
benford's Avatar
benford
Spark advance, vacume advance whatever you like to call it , I had a 78 supercab with a 400 , I did all the things you guys talked about , it turned out that the spark advance was not working , when its running and you set the timing ( by ear )
to make it run good you are advancing it too far , then when you shut it off it wont turn over coz the timing is too far advanced,
After I sold it A mechanic told me there are ( magnets i think )
in the distributor that get stuck and then the advance does'nt work,
anyway I would hardly ever drive that truck because of that,
So now you have one more thing to look at, Hope you can getter
goin
Benford
Old Sep 5, 2001 | 12:40 PM
Irondale90's Avatar
Irondale90
mostly I have seen that to be caused by timing too far advanced. or the vacume advace in the distributor is frozen in an advanced state (you know..rust) Cold it starts fine but when hot it will start hard. Timeing needs to be retarded. Are you running a stock ignition box. Check to see if it is overheating, or the potting(black gue on the back of the box) is melted. If so get a new one. They are less than $20.
Old Sep 5, 2001 | 11:51 PM
77_f250_460's Avatar
77_f250_460
it seems that we have all had the same problem, i got mine to go away pretty easily though,
my engine doesnt leak any fluids so the starter was already clean so i replaced it as it was stock, replaced all battery wires with heavier 2 gauge wires and got a new battery and solenoid, then had a tuneup and it was good to go
