Modular V10 (6.8l)
'07 V10 availability
Old Jun 17, 2006 | 02:37 PM
polarbear's Avatar
polarbear
Just as an update, we got our first '07 V10's in- which should answer the 48-state availability questions.
Old Jun 17, 2006 | 07:42 PM
captchas's Avatar
captchas
Guest
Thank You Pollar Bear
Old Jun 18, 2006 | 01:12 AM
Antelope V-10's Avatar
Antelope V-10
CA. still a no go?
Old Jun 18, 2006 | 08:53 AM
BlueOval5.0's Avatar
BlueOval5.0
Ernie,
Are these 250's or 350's?
Eric
Old Jun 18, 2006 | 11:38 AM
polarbear's Avatar
polarbear
350's- one S/C, one King Ranch Crew. We don't order much in the way of 250's anymore- not enough of a difference in truck or pirice.
Old Jun 18, 2006 | 12:52 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Duplicate post.
krewat's Avatar
krewat
polarbear, is that in CA? or Oregon?
One other thing, can you tell if they have an EGR valve?
Old Jun 18, 2006 | 08:13 PM
captchas's Avatar
captchas
Guest
pollar bear is in the portland OR. area
Old Jun 18, 2006 | 09:31 PM
biz4two's Avatar
biz4two
Arrow
Then they should have the 10,000 lb rating. Which would keep in the same line as other posts regarding the '07 V10 and emissions.
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Jun 19, 2006 | 07:07 AM
azdrawdy's Avatar
azdrawdy
F250 vs. F350
I agree with you 100% as far as the price from Ford. HOWEVER, in my case, I got smacked big-time with my county property taxes because it is a designated X30 vehicle. The tax on my F350, although it is a 2wd, gas, extended cab, is nearly double what an F250 would have been.
I pleaded my case to the local tax assessor. I was told that I drive a big-ol honkin' one ton truck. I told him that my "Big'ol honkin' one ton" is far lighter than 99% of what is on our roads around here: Diesel, 4wd, crew cab, and quite often long bed. I saw the writing on the wall, smiled at him and said: "Well, I guess I have to pay to play."
I then inquired about my fifth wheel, which was delivered last week. I was told it is in the exact same tax category as my one ton. However, if my fifth wheel had a motor (i.e. Class A), then it would be taxed at the rate of an F250. That made no sense to me.
Whatever, I would not change my decision from a 350 to a 250. I pulled my 11,000 lb fiver for the first time last Sunday. Life is good! I will post more, with pics, later.
Michael
Old Jun 19, 2006 | 11:27 AM
polarbear's Avatar
polarbear
In Oregon there is no property taxes, and licensing is determined by the vehicle configuration, not the GVW. For example, a 10,000 lb GVW cab-chassis will have commercial plates, while a 11,400 lb GVW pickup can run on conventional plates.
We are going to fatten up a bit on V10 inventory, since we anticipate this motor will not resurface in the '08 lineup after the 1st of the year.
Old Jun 19, 2006 | 05:19 PM
crazyrwe's Avatar
crazyrwe
Hey Polarbear,is there anyway you can find out for me a vin# or any information on the truck I ordered?,thanks,Al.
