Computer Chips & Tuners
06 Mark LT- ECM Alpha Numeric Code Location ?
Old Jun 17, 2006 | 09:31 AM
Beechkid's Avatar
Beechkid
Thanks in advance...
Going to be purchasing a programmer and need to find the label with the code....looked in door jams and doors, where else could it be located.
Old Jun 17, 2006 | 01:17 PM
polarbear's Avatar
polarbear
On the ECM itself?
Old Jun 18, 2006 | 08:37 AM
Beechkid's Avatar
Beechkid
Ecm
I was told by a proammer that it was a sticker typically found in the door jam on Ford trucks (sent pic also) but it wasn't there on the LT. By chance would you know where the ECM is located on the LT?
Old Jun 18, 2006 | 11:42 AM
polarbear's Avatar
polarbear
passenger side behind to glove box, i believe
Old Jun 19, 2006 | 08:18 AM
Beechkid's Avatar
Beechkid
Thank you!
Much appreciation!
Old Jul 7, 2006 | 11:29 AM
Troyer Performance's Avatar
Troyer Performance
Former Vendor
No, the PCM is actually located under the hood, at the top of the firewall, just left of center on ALL 2004 & newer F-150 models (which includes the Lincoln Mark LT). You will find a code sticker usually just to the right of the PCM. The code format will be 3 letters followed by 1 number, and some of the more common codes for 2006 Lincoln Mark LT's are: DCC0, MJZ0, MJZ2 & UVE2.
We've specialized in performance tuning the F-150 platform longer than anyone else, and provide assistance to a number of the major chipmakers as a result of our many years of R&D on them, so we know them well - this is also why most people come to us for our Troyer Performance custom tuning for these vehicles, as our results are well known to deliver maximum safe & sustainable power & performance gains, as well as the best driveability, etc.
We also offer special discounts for members of Ford-Trucks.com.
Good luck finding your catch code, and don't forget that there is a good possibility that your truck has had it's PCM updated to a completely different code without your knowledge - this can happen either at the factory before it was ever shipped to the dealership, or at the dealership prior to the first owner taking retail delivery, and never be documented (though they are supposed to be documented with a "Notice of Authorized Modification" sticker under the hood, this is rarely done any more). This is why in many cases we will send the XCal 2 out blank so you can read it' actual strategy, and then email the tunes, which is very easy to do to make sure everything is perfect. This is just FYI so you'll know.
ktkoch
1997 - 2003 F150
Feb 6, 2015 04:59 PM
derek4343
2009 - 2014 F150
Dec 29, 2013 10:51 PM
gjnicholas
2004 - 2008 F150
Apr 27, 2011 12:02 PM
fp_5
Apr 14, 2009 08:37 AM
lighthouse08
Jun 21, 2008 10:50 PM
