6" lift with 37" wheels ""overdrive""
Matrix, I almost forgot..........Welcome to FTE!
Also, try the gear calcultor in my signature, it may help you pick the gears you want. Keep in mind, I'm running 36's and went from 3.73's to 4.56's and I'm still kicking myself for not going to 4.88's. They would have been perfect with the V10.
As to cost; for a 4wd truck, including parts and labor, expect anywhere from $900 to $1800 for a re-gear. It REALLY varies by area and what brand parts / level of install kits you use.
Originally Posted by matrix-uc
I will try the superlift deal. any idea on the $$,
Originally Posted by El Gato
BFR250SD, how do you figure4.56s? I am just curious.
Just keeping within the meat of the power band and the inherent lower rpm range of the diesels.
The V10 with that size tire, like mine, needs a few more RPM's and the V8 slightly more.
Like I said, I'm still kicking myself for thinking that 4.88's would have been too deep. The math doesn't lie.
I have a 2000 f-350 crew lifted with 37" wheels. it is not calabrated for the wheels and I am having trouble with it staying in over drive. is there a chip or a reprogram that I can do to elivate this problem. thanks Ben
where are you located?
You can regear or buy the Superlift product!
I am in the far west burbs of Glendale Heights, work in Lisle
IM me and I will give you the names of the shops
bob
