wiper swap question
Old Sep 16, 2001 | 07:55 PM
imgooch1's Avatar
imgooch1
wiper swap question
Old Sep 16, 2001 | 11:47 PM
69man's Avatar
69man
wiper swap question
I have a 1969 f-250 and i saw that some 73-79 trucks have intermitent wipers i was wondering if i could put that into my truck with out much problem. and what do i need. i assume teh new switch and the control box. but do i need the motor as well and if i need the motor does it bolt up the same way into a 69?
69man
'69 f-250 with a paint job and promise
Old Sep 17, 2001 | 04:02 AM
Supercab's Avatar
Supercab
wiper swap question
Your wiper swap should be a plug-in and go, you can use any intermidnt setup from Ford cars as well, that use dash mounted switches, like 70s TBirds & Cougars, Lincolns, ect, just remove the switch, and the intermidnt box that is with it, & simply plug it into your truck, after removing your standard two-speed switch, you DO NOT need to change the motor itself.
Old Sep 17, 2001 | 09:00 AM
73Custom's Avatar
73Custom
wiper swap question
[font color=red size=2]The switch and control box are the same up to '91. I recently got a switch and box out of an '81 Bronco and it plugged right into my '73 F100. They are more common in the newer trucks.
Marty
"Cleverly Disguised as a Responsible Adult"[/font]
Old Sep 17, 2001 | 03:29 PM
69man's Avatar
69man
wiper swap question
Thank you both for your help.
69man
'69 f-250 with a paint job and some promise
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
