Side moulding separating
Old Jun 15, 2006 | 10:12 AM
MEDF150's Avatar
MEDF150
95 F150 Side moulding separating from the drivers door. I believe a double sided type tape was originally used. I'm worried about bending the moulding trying to get the part that still sticking off to replace the adhesive. What adhesive should I use to stick it back on? Where to get it? Thanks....... First post
Old Jun 15, 2006 | 01:15 PM
GWall's Avatar
GWall
The double-sided tape is available from most automotive paint stores. I have gotten it several times from Napa in my area.
Old Jun 15, 2006 | 03:05 PM
ncranchero's Avatar
ncranchero
3M makes a superior double sided tape, get the gray instead of the black. If the moulding looks bent after you remove it as happens a lot of the time, you will need to peel off the silver strip that is under the factory adhesive tape. That will allow it to straighten out again. If it's not bent leave the silver strips on and apply the new tape to it.
Old Jun 15, 2006 | 08:33 PM
mississauga's Avatar
mississauga
I agree with using the 3m products. Make sure you degrease the area. If you leave the moulding in the sun for a bit it will also help in straightening it out if required.
Old Jun 16, 2006 | 12:18 AM
MEDF150's Avatar
MEDF150
Thanks for the info and tips. 3M it is
