transmission problems
Old Jun 14, 2006 | 02:55 PM
tity(.)(.)stroker's Avatar
tity(.)(.)stroker
I have a 2001 250 psd that i just bought 2 days ago with 198 thousand miles. Three hours after i bought the truck the transmission breaks. The engine still runs and everything but the wheels dont move in drive, it works in reverse with no problem. I believe this is a tourque converter failure but someone please correct me if im wrong. The dealership says they need to replace the whole transmission, which i dont believe needs to be done since the truck runs fine in reverse. Please help me before i end up paying for a whole new transmission.
Old Jun 15, 2006 | 09:01 AM
Casey's Avatar
Casey
You're wrong.
The torque converter works exactly the same in reverse as it does in drive. If it was the torque converter it wouldn't move in reverse.
You need a trans rebuild or replacement.
