Sponsored by: Auxito
Door Locks
Old Jun 14, 2006 | 02:30 PM
IDAHOMountainMan's Avatar
IDAHOMountainMan
Door Locks
My power door locks are sticking on my 2000 F150. They will not open with the remote and I have sprayed WD-40 in the locks to no avail. Is there an easy fix?
Old Jun 14, 2006 | 03:21 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
You Could Always Replace Them
6L3Z25218A42AA FTE $43.22 RH
6L3Z25218A43AA FTE $43.22 LH
Ed
Old Jun 14, 2006 | 11:27 PM
pilot10's Avatar
pilot10
Do they work properly with the switch on the door? If so then
I'd check/replace the remote battery. Do you have a second remote you can try?
Tim
Old Jun 15, 2006 | 02:10 PM
IDAHOMountainMan
Door Locks
Tim,
Thank you for responding. I have changed the batteries in the remote and it is okay. You can hear the door locks trying to open, but they seem to be stuck.
Old Jun 15, 2006 | 02:31 PM
Grandpa's1983's Avatar
Grandpa's1983
sounds like the actuators are just starting to go bad, you will probably have to replace them to get them working right again. discountfordpart is offering you a good price if that includes shipping, regular $60 at dealership.
Old Jun 16, 2006 | 10:29 AM
mhamric's Avatar
mhamric
This should help if you are wanting to replace them yourself:
https://www.ford-trucks.com/forums/s...lock+actuator+
I'm going to be doing this later this summer...
Old Jun 16, 2006 | 11:09 AM
doctor-rv's Avatar
doctor-rv
Smile
Try removing door panels and lubing latches and linkages and all moving parts with some good lubricant(not wd-40) like spray white grease or simular. Be very careful with door panels if you have not removed before-remove all visible screws and then lift up and out-do not pry. Good luck, let us know what you find.
