Timing chain opinions
Old Jun 14, 2006 | 07:34 AM
lifted77f250's Avatar
lifted77f250
What are your opinions on timing chains? Should a double roller timing chain be used and how much of a difference does it make on an engine that isn't highly modified?
What are some brands that are ok to use?
Old Jun 14, 2006 | 08:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
There are double roller and "true" double roller. The true double roller actually has rollers on the chain. Cheapos don't.
The wafer-style chain is fine for stock.
When do you need a better chain? When you go into big cams and VERY stiff valve springs.
Brands? No idea. Melling? Cloyes? Guys?
Old Jun 14, 2006 | 01:47 PM
averagef250's Avatar
averagef250
Hands down Cloyes. Timing chain quality isn't just something you determine by how much spring pressure you have. If you want an engine to last, put a good chain in it.
Old Jun 14, 2006 | 03:30 PM
markjw's Avatar
markjw
Make sure you remove the spacer behind the cam gear.. A Cloyes cam gear and maybe others come's with a spacer machined right onto the back of the gear,at least the one in my truck did.... so if the the original spacer is not removed, it will push your cam back into your block about 3/16th inch...Causes a whole list of problems.
Old Jun 15, 2006 | 11:51 AM
lifted77f250
Ok thanks on the heads up.
Old Jun 15, 2006 | 04:21 PM
biz4two's Avatar
biz4two
Arrow
My 390FE is pretty much all Edelbrock components. The timing chain set is no exception. Part #7808. Good quality product, but only recommended for Edelbrock or stock cams.
OBTW...they are made by Cloyes.
biz
_______________________________
1976 F150 LWB 390FE NP435 NP205 4x4 3.50s
Old Jun 15, 2006 | 08:40 PM
Tmod700's Avatar
Tmod700
I am going with rollermaster for the timing chain.
Tmod
Old Jun 16, 2006 | 07:10 AM
lifted77f250
Are there any opinions about the summit brand of parts. I have heard mixed reviews.
Old Jun 16, 2006 | 06:13 PM
averagef250
Summit=junk. I ordered a cloyes true roller from them a while back and they goofed and sent a summit pile of junk instead. Every link was stamped taiwan and looked like junk. Ended up returning it and getting the cloyes for the price of the summit chain ($70 savings). Has anybody ever bought anything "summit brand" and had it be quality? They're like barely-scrape-by parts that you're forced to run only when you're completely broke and have to have something running.
Old Jun 16, 2006 | 07:45 PM
Barry_R's Avatar
Barry_R
Cloyes Tru-Roller. Nothing else is even close. When I ran Speed-Pro I could have the Speed-Pro timing sets for free - - and I still went out and paid for the Cloyes stuff. I like them that much.
Old Jun 16, 2006 | 08:29 PM
lifted77f250
Does summit sell the cloyes?
Nevermind I found them. The reason I asked about summit is because I have some friends who have used their timing sets with good results.
Old Jun 17, 2006 | 12:46 AM
Putt's Avatar
Putt
Yes, I have bought Summit branded parts that were quality.
Old Jun 18, 2006 | 05:46 AM
f700's Avatar
f700
timing chain ?
Hi from australia just reading your threads im rebuilding a 361 ft (truck) motor
i use a melling oil pump and timing chain hope this help you
