radiator hose
Old Jun 14, 2006 | 02:21 AM
Ak65F100's Avatar
Ak65F100
radiator hose
460-65f100 owners, what kind of upper radiator hose did you use ??? My has part number of 120688 which means nothing to NAPA,CARQUEST or SCHUCK. Thmosate end is 1 1/2 " , radiator end is 2" any help appreciated. thanks you.....
Old Jun 14, 2006 | 06:34 AM
William's Avatar
William
I told the parts guy 78 F250 with 460. The hose almost fits perfectly.
Old Jun 14, 2006 | 11:08 PM
Ak65F100's Avatar
Ak65F100
radiator hose
William, just want to say THANKS, Carquest came up with hose 21045. Had to trim about 1/4" off themosat end.
Old Jun 15, 2006 | 03:29 AM
banjopicker66's Avatar
banjopicker66
Now to throw a wrench in it: William's answer is perfect if you are using a pre-80's radiator and pre-80's V belt setup.
The thermostat housing is parallel to the ground.
I am using a 1966 radiator (same hose diameters, though) originally for a 352, but with a 460 that has the serpentine belt setup.
The thermostat housing is not flat, but angles upwards to the right (passenger) front of the truck. Using that hose will kink it too much, restricting coolant flow.
I used an upper radiator hose from an '86 460, and cut 1 to 2 inches off each end, and it fits almost perfectly. After running it a few times, the rubber seated itself to the correct shape as though it was made for it!
Old Jun 17, 2006 | 10:48 AM
William's Avatar
William
Happy ending! BP I think if I had started with a serpentine system I would have kept it but I honestly believe converting a V belt system over to serpentine is to much work for the benefit. My fat 460 is in and running soo sweet!
eric8
Mar 12, 2017 02:42 PM
Bob-93021
Feb 1, 2017 12:21 PM
losio
Jul 8, 2016 06:43 PM
fast65back1
Dec 29, 2015 10:56 AM
driverman1
Dec 8, 2010 07:25 PM
