Sponsored by: Real Truck
Spare tire bracket?
Old Jun 13, 2006 | 09:39 PM
khackney's Avatar
khackney
Spare tire bracket?
I have a 99 CC F250 and just recently picked up a tire and wheel to use as a spare. I bought the truck used and it did not have one. Tried some searches regarding this question but couldn't find anything. My question is does the spare require any kind of bracket or anything to help hold it in place? Or is the winch all that is required? Thanks for your assistance.
Old Jun 13, 2006 | 10:03 PM
dagren99's Avatar
dagren99
Spare
`Just the winch is required - Cranking it up & down requires a key that goes on the end of the jack handle. Hopefully you got the key w/ the truck.
Check your winch over carefully - several guys have had the cable snap and the spare go bouncing down the road. That may be why your truck didn't have a spare.
DG
Old Jun 13, 2006 | 10:09 PM
khackney's Avatar
khackney
Spare
Thanks...heading out for a long trip and trying to make sure everything is in order.
Old Jun 13, 2006 | 11:22 PM
V10man's Avatar
V10man
The key is an option. Chances are you won't have it.
Old Jun 14, 2006 | 09:12 AM
DetailerDave's Avatar
DetailerDave
What is this key? The winch has a square-ish hole that the lug wrench fits into. I just replaced the winch on mine. The lug wrench fits, but doesn't seem to me to be exactly the right tool to fit the shape of the hole in the winch. Or am I putting the wrong part in there (small semi-pointed end)?
Old Jun 14, 2006 | 10:29 AM
BFR250SD's Avatar
BFR250SD
There is suppossed to be a "key" (basically like a locking lug nut key) that engages in the hole. The extensions for the jack don't really fit it.
Old Jun 14, 2006 | 10:33 AM
Fat Diesel's Avatar
Fat Diesel
My early 99 doesn't and never did have a key, and a late 99 probably doesn't either. The only bracket is the one on the end of the cable. Just make sure the tire gets seated right. It can get sinched up and not be seated correctly just to come loose down the road. A loose cable is the #1 cause of failure and your spare dropping off somewhere along the road...
Old Jun 14, 2006 | 11:31 AM
dagren99's Avatar
dagren99
Key
I think the key got intoduced when they switched body styles @ 99.5 model year. My 00 has the spare tire winch key.
DG
Old Jun 14, 2006 | 11:24 PM
khackney's Avatar
khackney
Spare
I don't have the "key" or the need for one on my setup. I use a 3/8" ratchet extension and it does the trick. Thanks for all the info.
Old Jun 14, 2006 | 11:54 PM
V10man's Avatar
V10man
The part that fits into the winch is one of the 2 rods for cranking up the jack. The one with the flattened end that fits into the jack. Using the lug wrench where the square hole is, slide it over the end of the rod. Make sense?
Old Jun 15, 2006 | 07:54 AM
DetailerDave
OK, that's what I meant. The extension piece, not the lug wrench itself.
6t6merc
16
Nov 27, 2018 10:43 AM
johnmel59
Mar 21, 2015 08:06 PM
Wonkafan
13
Jun 6, 2014 04:00 PM
Anomic
Jan 26, 2014 05:10 PM
