It is 1200watt inverter that I want to put on a dual battery ford powerstroke superduty. Will this work OK for a truck that is running (not use the inverter if the engine is off?) I am planning on a 14 hour road trip and it will be on the entire time?
Thoughts? Cooling is proably not going to be an issue. THANKS
I wouldn't use that sucker with the engine off, you're right. That'll draw some power. I imagine it would be perfectly safe using it while driving or letting the engine run. If there's a setup that can handle 1200 watts, it would definately be a big truck.
