help with my 400
Old Jun 12, 2006 | 05:14 PM
78FordF2504X4's Avatar
78FordF2504X4
help with my 400
In my 400, when ever i get up around 2500-3500RPM it seems like the engine is flooding out. I have no loose vacum lines that i can see, my spark plugs are goldish brownish, and my timing is set to where i have a good smooth idle, i think its set at 8 degrees. Anyone know how to fix this?
Old Jun 12, 2006 | 07:51 PM
danlee's Avatar
danlee
How are your spark plugs and wires, cap, rotor etc. Is it under load when this occurs? A poor ignition system will work well at light load and start to fail under heavy load.
Old Jun 12, 2006 | 08:23 PM
78FordF2504X4
spark plugs are brand new and are a brownish color. the cap is brand new the rotor is in good shape. It happens when i get above 2500RPM. It sounds like it is flooding out.
Old Jun 12, 2006 | 08:28 PM
danlee's Avatar
danlee
Have you checked your fuel pressure. A poorly regulated fuel pump can put out too much pressure at high RPM and blow open the needle valve.
Did you recently replace your fuel pump? Some replacement pumps will do this.
Old Jun 12, 2006 | 08:32 PM
78FordF2504X4
No i havent replaced the fuel pump. I think it has the stock fuel pump. I dont know for sure because the engine has been rebuilt and i dont know everything that was done. I thought about buying a fuel pressure regulator a while back to hopefully solve this problem.
Old Jun 12, 2006 | 08:41 PM
danlee's Avatar
danlee
You should be able to buy an inexpensive fuel pressure gauge to check your fuel pressure.
Does it also do this when you rev it in neutral?
Old Jun 12, 2006 | 08:43 PM
78FordF2504X4
No it doesnt do this in neutral. It usually does it in 2nd-4th gear. And it only does it on occasion. But it is common enough to make it a problem. What should the fuel pressure be at?
Old Jun 12, 2006 | 08:47 PM
danlee's Avatar
danlee
The fuel pressure should be 5 to 7 psi.
If it doesn't do it in neutral, it is not fuel pressure. It is load or motion sensitive.
Check the carb mounts, manifold bolts, loose electrical connections, etc.
Old Jun 12, 2006 | 08:50 PM
78FordF2504X4
Do you think it could have anything to do with size of carb or the adjuster screws on the carb?
Old Jun 12, 2006 | 08:51 PM
danlee's Avatar
danlee
Another place to check is the fuel filter. A partially blocked fuel filter can cause symptoms like these.
Old Jun 12, 2006 | 08:53 PM
danlee's Avatar
danlee
What kind of carb is it?
Old Jun 13, 2006 | 12:34 PM
78FordF2504X4
Well it is a Carter 4 Barell. All the jets are the same size to. I am working on getting the exact name of the carb at this time.
Old Jun 13, 2006 | 12:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bad ignition or insufficient distributor advance can also cause this problem.
