Changing Fuel Filters
Old Jul 25, 2006 | 01:48 PM
  #31
dman98765's Avatar
dman98765
OK, call me a regulation ******* but where is the TECH folder "sticky"? It's time for me to buy a 36mm socket and get busy!
'05 F250 PSD
Old Jul 27, 2006 | 10:27 AM
  #32
BPofMD's Avatar
BPofMD
Veteran: Navy
Look at top of page one....3rd item! Don't feel bad..I looked everywhere but there too.
Old Jul 27, 2006 | 10:38 AM
  #33
Bud in Texas's Avatar
Bud in Texas
Maybe what he meant by the right place is that if you buy a filter socket, it's reversible so it fits both filters; oil and fuel.
Old Jul 31, 2006 | 06:54 PM
  #34
sriddle's Avatar
sriddle
My fuel pump went T/U when I was in the middle of the desert. I had to have the it towed to Mojave and it took them no less than 20 days to get to my truck and fix it. I told them to make sure and change the fuel filter while they were changing the pump. They tried to charge me $178 just to change the fuel filter they were going to have to put in the new pump anyway. Also in looking at the invoice it only listed Qty 1 and one part number so I question did they change the one on the engine? The filter supposedly cost $98. I want to change the one on the engine if they didnt.
Old Jul 31, 2006 | 07:21 PM
  #35
guydiver12's Avatar
guydiver12
fuel filters
sriddle. The filters come as a kit of two, they are not sold separately as far as I know, so the charge is for both.
Old Jul 31, 2006 | 07:59 PM
  #36
NavyPowerstroker's Avatar
NavyPowerstroker
I am sure they used the kit which has both. That is pretty much what the dealerships around here are charging for them, and as guydiver said, I don't believe you can buy them seperately at the dealer. What was the part number listed on your invoice?
Old Jul 31, 2006 | 08:12 PM
  #37
BIODZLX's Avatar
BIODZLX
Check your local International dealer, I got the 2 filter set for $33 plus tax! I bought 4 incase there was a mistake! I also tried to buy just the engine mounted filter there and they told me that they were only avail as a set. They are the exact same thing I bought at the Ford dealer last month. Nice savings......
Old Jul 31, 2006 | 09:42 PM
  #38
sriddle's Avatar
sriddle
QTY: 1
FP number: 3C3Z-9N184-CA Element 874723
List Price: 99.35
One would think this came with the fuel pump. I cant imagine they would take the fuel pump off without changing the filter that is attached to it.
The thing that burns me is they replaced the front and rear mains which was very involved and included removing the transmission but they were going to charge me $178 bucks for the changing of a filter they should have done anyway.
That said when it failed I was so upset I was ready to sell it. When I picked it up in Mojave 20 days later I fell in love again!
Old Aug 17, 2006 | 10:35 AM
  #39
Lonewolftx's Avatar
Lonewolftx
Thumbs up
Sears has them online for $8.95 and free shipping. You can always go to the local Sears store too, call 1st thought.
Old Aug 17, 2006 | 05:10 PM
  #40
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
There is no way that Sears has quality fuel filters for the 6.0L motor. Even the 7.3L (if they made a mistake) are more than $8.95/ea. If Sears did have them, them for the 6.0L (I have no proof either way).. they are more than $8.95!!!
I would call and double check, but a quality fuel filter (even poor quality) for a 2 filter kit is not $8.95!!!!
Please post the item or model number for this filter kit so I can call and verify please.
Probably a "gasser" fuel filter?
Old Aug 17, 2006 | 05:40 PM
  #41
NavyPowerstroker
I was thinking the same thing but maybe he means the socket?
Old Aug 17, 2006 | 05:41 PM
  #42
A. Michael Foxtrot's Avatar
A. Michael Foxtrot
You sure he's not talking about the socket for the filter?
edit: beat me to it... And I just checked to make sure nobody had already replied.
Old Aug 18, 2006 | 07:25 AM
  #43
Lonewolftx's Avatar
Lonewolftx
Yes, it is the socket, not the filter. Here is the link . . .
http://www.sears.com/sr/javasr/product.do?pid=00950752000&vertical=Sears&BV_UseBV Cookie=Yes
Old Aug 22, 2006 | 03:22 PM
  #44
Lonewolftx's Avatar
Lonewolftx
"If you DO want to DIY, the above post has the filter kit (2 filters) and there is also a replacement drain plug for the HCFM you may want to get, part #2589259C91 - $13 or so from Intl truck dealer + $30 for the filters and you can see why $250 is obscene. Mine is on my list for this week, I figure it can't take more than 1 HR or so from reading other posts. Even if I make a bit of a mess, I can afford some cleaning supplies for the saved $$ and I'll get better by the next time. "
What does thius replacement plug part do instead of the stock plug? I have an '06 6.o and there is no lever like the manual says so does this convert it?
Old Aug 22, 2006 | 05:29 PM
  #45
NavyPowerstroker
No it does not have a lever but it does have a knurled thumb type screw that you can twist in there. The stock one can strip out so the replacement one is harder to strip out and if it does there is something to get a hold of so you can at least get it out. BTW the change should only take you about 15 minutes. 30 if it is your first time.
