93 f-150 abs problem
Old Jun 11, 2006 | 06:08 PM
ledfordwc's Avatar
ledfordwc
i've got a 93 f-150 and the abs light is flashing and the brake lights don't work i've replaced the switch on the pedal and all the fuses are good. the light is flashing 15 times then it will pause and flash 15 more times and it does this over and over. any suggestions?
Old Jun 11, 2006 | 06:33 PM
Beast12's Avatar
Beast12
Thread moved to 87-96 F-Series trucks forum.
-Matt
Old Jun 12, 2006 | 12:43 AM
Lone Wolf #2's Avatar
Lone Wolf #2
The flash pattern of your abs light would seem to be a code. I'm at work , otherwise I'd try to look it up for you. Try calling the local dealership and ask them what a code fifteen would be for the brake system.
Old Jun 12, 2006 | 01:32 PM
Lazy K's Avatar
Lazy K
The first thing you have to do is get the stop lights working. The ABS will not work if it does not receive a signal from the stop light switch. You should have 12v at one of the wires connected to the stop light switch at the pedal. If not then you could run a wire from the fuse. Once you have the stop lights working disconnect the battery for about 30secs to reset the ABS computer and the light should stop flashing.
Modahl135
Oct 30, 2014 04:35 PM
pnp522
Dec 3, 2013 10:55 AM
Bob Murrell
Aug 14, 2005 02:43 PM
Scotto
Jun 3, 2003 09:37 AM
dbrown13
Feb 1, 2003 07:52 PM
