if you like that whistle, you can strip off the insulation on the hot side IC pipe, and it will whistle a whole lot more! how do you like the Darth Vader exhale?
Dum question, what did you mean by stipping off the insulation on the hot side of the IC pipe ?
I just installed the WW wheel and kinda like the whistle
the 3'' pipe on the driver side of engine bay comeing off of the turbo. this pipe is covered in aluminum heat tape and insulation it's a b@#!% to get off but doing so will allow you to hear more of the ww whistle. you should check in to the 6637 air filter mod it also makes a difference. I had my IC tubes powder coated red I will try to post a picture, it really looks good.
I am not really sure ,maybe a mail order . I know there is not hear in Kannapolis NC.
stripping the insulation off really is not that bad ,I like to think its like skinning a deer, just cut the tape the full lenth and work your way around the tube. the adhesive comes off pretty good with pure acitone.
