Old Jun 11, 2006 | 02:19 PM
78FordF2504X4's Avatar
78FordF2504X4
400m
Hey does anyone know for sure if the 1978 Ford F250 400 engine is a small bloxk or a big block. I have read that it is the same as the 351M with a taller deck height. Does anyone know foe sure?
Old Jun 11, 2006 | 02:55 PM
Jmudder79's Avatar
Jmudder79
It's the same block as the 351M, just with a different stroke I think. I'm not exactly sure on all the specifics, but there are other people on here who are more knowledgeable then me. Check the engine forums. There is a ton of this kind of info in there.
Old Jun 11, 2006 | 02:59 PM
78FordF2504X4
Thanks alot. Thats what i thought. I have done alot of research on this. The only reason i ask is becasue of the valve covers look like big block covers.
Old Jun 11, 2006 | 03:03 PM
Jmudder79's Avatar
Jmudder79
I don't think its technically a big block(429,460,..). It also isn't a small block(289, 302, ...). Its somewhere in between. Like I said, the engine forums have stuff like this all over them. You should check them out.
BTW, Welcome to FTE!
Old Jun 11, 2006 | 03:06 PM
78FordF2504X4
400m
I was wondering if anyone knew for sure if the 400m in my 1978 f250 is a big block or a small block. I have read that it is a small block with a taller deck height. But the valve covers look like they are big block valve covers. Also if it is a small block, would i be able to put 351c heads on it? Any info would be greatly appreciated. Thanks.
Old Jun 11, 2006 | 03:25 PM
grclark351's Avatar
grclark351
it's not a 400M, it's a 400. it's not a big block, or a small block, small and big block are chevy terms. what it is is it's a 335 series engine. 351C 2V heads are a direct interchange fit on a 400, they are both 335 series engines. 351C 2V heads do not have any emission features that the 78 heads have, but they do have better exhaust ports.
Old Jun 11, 2006 | 03:27 PM
78FordF2504X4
Thanks alot. Would you recomend the 351c heads on my 400 or should i go with a different setup?
Old Jun 11, 2006 | 03:31 PM
grclark351's Avatar
grclark351
depends upon if you need the emission features for visual inspection or not. the C heads are better than stock 78 heads.
Old Jun 11, 2006 | 03:32 PM
banjopicker66's Avatar
banjopicker66
You have posed an excellent question.
There is no Ford "big block" or "small block" designation. That terminology is originally GM in nature.
It has become generic in nature to mean engines over 400 CID, but when referring to Ford engines, it confuses more than anything.
Ford uses the term "Family" to differentiate between engine designs. The engine forums here on FTE are separated accordingly, and you can learn a lot just by surfing. You will notice how the FE and 385 Families span the 400 CID threshold, rendering the Big Block designation rather confusing:
Here are the basic families, as used since WWII:
Y-Block: 292 and 312 are the most common, used up to '64 in trucks.
FE, Ford Edsel engines: 332, 352, 360, 390, 406, 410, 427, 428. First used in light trucks in '65, discontinued in '76.
FT, Ford Truck: 361, 391, a heavy duty variant of the FE
Windsor series: 221, 260, 289, 302 (5.0) and 351W. First used in cars in the early '60s, introduced into trucks in the late '60s. Discontinued in '95.
335 Series: This includes the 351 Cleveland, 351 Modified and the 400. discontinued in the early '80s.
385 Series: 370, 429 and 460. Used up to '95.
Hope this helps!
Old Jun 11, 2006 | 03:34 PM
78FordF2504X4
I live in WY where there are no emmisions. Also do you think that i could get 500+ hp out of my 400 if i did everything right?
Old Jun 11, 2006 | 03:39 PM
73XAFalcon's Avatar
73XAFalcon
Yes you can get 500hp out of a 400 BUT you have to ask yourself what it is you intend to use the motor for. 500hp is not cheap for this motor.
Old Jun 11, 2006 | 03:42 PM
78FordF2504X4
Yes i know this. I hope to use this truck as an advertisement for my business. I also would like it to be a hot rodder and maybe give this year and model the respect it deserves.
Jmudder79's Avatar
Jmudder79
See what I mean. You picked a good site to join.
Old Jun 11, 2006 | 07:03 PM
LxMan1's Avatar
LxMan1
Oh, and there is no "M" behind the 400, it's 351C, 351M and 400 in the 335 series engine class.
Old Jun 11, 2006 | 07:08 PM
danlee's Avatar
danlee
You do not want to build a motor for 500 HP in a truck. You should build it for high low end torque and a broad flat torque curve.
To get 500 HP you need a cam with a lot of duration. This will kill the torque at low RPM. A light Mustang can get away with this, but a heavy vehicle needs that torque.
The best combos use 9:1, or 9.5:1 compression ratio, with moderate duration high lift hydraulic roller cams, ported or alloy heads for great head flow, headers, a good intake manifold with a 600 CFM carb.
There are many examples of what others have built or are building on this forum. Our sponsor Tim Meyer has some great parts to build this motor.
