I need help ive searched the forum,page after page,even posted in the wiring forum to no avail. I have 2 plugs I cant figure out, I looked in my haynes and chiltons manuals again to no avail. I have my 76 F-250 it has heater/ac/dual tanks setup, its all plugged in except 2 plugs driving me crazy. 1 is a thick gauge brown wire with white male plug and the other has 2 red wires/blk stripes going to a white female plug,I got no clue where these go, Ive looked and looked.
I know the thick orange wire coming from the heater label on fuse block plugs into the thick orange wire coming from my blower switch thats what my manuals show but those other 2 plugs Im clueless.They are coming from the passenger area under the dash where the blower and all are, thats all plugged in though.Where do they go or are they extras?
Im positive ,ill try and explain better,sorry. Ok the wiring coming from under the dash on the passenger side where the blower and all is, the ac/ harness its all plugged in under there, but it comes over to under the dash where the heater/ac controls are ,its all plugged in, except 2 plugs, the brown wire -white male plug, and the 2 red wires/blk stripes -white female plug.Its puzzled me, I might have to look on another truck with this same setup and see where they go.
i hope this works i dont know how to upload the pics here and my digital camera isnt working to good ,the bigger black plug ,plugs into the bottom of the heater/ac controls at the compressor clutch switch but the other 2 plugs have me puzzled.
Reason: adding info
these wires are under the dash right behind the a/c-heater controls.See the main harness has a connector goes to the blower fan switch and the blower fan switch has a thick orange wire coming off of it with a male plug and it plugs in to the thick orange wire female plug coming from the heater side, fuse box.The harness in the pic,comes from under the passenger area where the blower motor and all is, and comes up behind the ac/heater controls ,the connectors shown are the big black one goes to the ac compressor clutch switch ,but the other 2 im clueless.One is the brown wire male plug the other 2 red wires/blk stripe,going into a female plug.I thought maybe they plug in to togther?I know they have to do with the a/c.The brown wire with male plug is coming off the plug for the a/c compressor clutch switch .The 2 red wires/blk stripes,go back over to the under the passenger area where the blower motor and all are and go into 2 plugs,one of which goes to a relay, or resistor under the passenger area.
The Red/black wires run from the AC MODE switch over to the Heater resistor and to the Heater control switch (blower)
The Red/black circuit is denoted by red line.
I'm trying to figure out that Letter just above the red X.
Is it a B or an O ?
It appears from the schematic that these 2 connections just plug into each other
well I I plugged the brown wire male plug coming from the switch into the redwires/blk stripes with the female plug and tried it today ,started the truck and the blower and all was working fine,so I guess that was it, thanks, sorry for the trouble I just wanted to be sure and didnt want to fry anything,thanks again this place is a big help.
