Help it's not a Chevy
Old Jun 10, 2006 | 04:07 PM
sutphen77's Avatar
sutphen77
First of all great site.
does anyone have schematics or a diagram on how to assemble the front end of my 1970 390. I have been rebuilding chevy's for many years but need some assistance on the front of this motor. There are a few more parts like cam retainer, fuel pump actuator and an outer spacer for the crenk. I am trying to make sure I have all the parts and assemble it correctly.
For $200 I got a block, perfect crank, and a rebuilt tranny. The heads where rebuilt and the block was decked honed and ready for assembly.
I wish i could figure out how to put the damn front end together since I didnt unassemble it I dont know how it goes back together. If you give me a Chevy I could put it back together in my sleep. Cam retainers, fuel pump stuff extra spacer around the crank where the hell does it go. And above all why didnt a pin come with my ISKY cam now I have to find one of those
Thanks for all your help in advance, Jim
Old Jun 10, 2006 | 04:44 PM
Bear 45/70's Avatar
Bear 45/70
Try here for pics of how things go.
http://www.gessford.com/images/352-390Parts&pics.htm
Old Jun 10, 2006 | 05:45 PM
Madmike33's Avatar
Madmike33
Welcome to FTE Sutphen77, first of all you came to the right place for your info, the guys here are a great help. 2nd you shouldn't use the C word here... just kidding. You should have what you need with link offered by Bear if not post back.
Madmike33
Old Jun 10, 2006 | 07:04 PM
sutphen77's Avatar
sutphen77
Thanks for the welcome Mad anf a special thanks to 45/70 that was exactly what I needed. I am glad I didnt put it together I see I am missing a few pieces.
Thank you all for your help, Jim
Old Jun 11, 2006 | 03:00 PM
sutphen77's Avatar
sutphen77
thanks to 45/70 I see I need part numbers 6700-6310 and 358963-5. I am glad I just didnt start putting the thing together.
Thanks 45/70, next time you are in the Southwest Florida area let me know
Old Jun 12, 2006 | 12:00 PM
sutphen77's Avatar
sutphen77
is part number 6265 (spacer camshaft gear or sprocket) needed. In the parts list page 9 is sayes do not use with C8AZ-6256A. Page 9 is alo atteched
Sorry for the large pics I don't know how to re-size
Old Jun 12, 2006 | 01:02 PM
Bear 45/70's Avatar
Bear 45/70
If you are running cam C8AZ-6256-A then no, otherwise yes unless your cam manufacture says otherwise in their instructions. A way to tell is the the cam lobs should be centered in the lifter bores when the front of the cam is against the cam retainer. If they are to far forward then you need the spacer.
Old Jun 12, 2006 | 02:47 PM
fordraceboy's Avatar
fordraceboy
i've never seen that spacer before in any of the FE's i've rebuilt. i don't believe any of the modern cam makers assume the use of that, so any cam you buy new won't need it.. JMO
Old Jun 12, 2006 | 04:09 PM
Bear 45/70's Avatar
Bear 45/70
I have and if the cam needs it you better have it or you will eat lifter as the get on the edge of the cam lobe. Most of the older FEs from the mid 60s thru the early 70s had them from the factory.
Old Jun 12, 2006 | 05:07 PM
fordraceboy
I never noticed, learn something new each day.. of course, I admit i've never actually looked for one either, they may have been stuck to the end of the original stick..
Old Jun 13, 2006 | 07:59 AM
sutphen77's Avatar
sutphen77
I dont think I need it because the aftermarket timing gear has the spacer as part of gear itself.
Thanks for all your help, I just need to locate part number 6310, do you have any idea where I could find one of these
Old Jun 13, 2006 | 11:14 AM
Bear 45/70's Avatar
Bear 45/70
Thats called an oil slinger and I would assume the Ford parts man could get you one.
Old Jun 13, 2006 | 02:59 PM
sutphen77's Avatar
sutphen77
"ASSUME" being the word. I called a few ford dealerships and I got every excuse from "our books dont go back that far" to "what is an oil slinger"
once again 45 you have been a world of help, thank you for everything. If I had a closeup picture I might attempt to make one
FOUND ONE
Old Jun 13, 2006 | 07:50 PM
Bear 45/70's Avatar
Bear 45/70
It's always fun to make An *** of U and ME when I start assuming. But then again the local Ford dealer here has been in business for 70+ years and finds me things like the FE windage tray which haven't been in an engine since the last 60s. Me thinks your local dealers are lazy.
Old Jun 13, 2006 | 08:55 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Hell the FE motor was out of production before those young Ford employees were born. All the good dealer mechanics with knowledge of FE's are retired or dead by now.
.....=o&o>.....
