PITA to change but I use sbc doughnut gaskets. I don't have the number. You need the shiny silver ones with no fiber in them 2in dia. The pipes wear and the factory ones will not fit tight. You can use a pipe expander to streatch them back up to size if you have one. The sbc gaskets are thicker and softer to conform to the pipe.
It was under warranty, $106 deductable. They said; engine leak turbo tubes advise covered repair under di warranty 100 ded checked found bad exhaust leak from y-pipe at turbo remove flange bolts stuck and cracked turbo elbow replace both pipe and elbow reassemble rear exhaust retested ok.
