ESOF problems HELP
Old Jun 9, 2006 | 12:59 PM
dmueller71's Avatar
dmueller71
ESOF problems HELP
OK guys, I need your help again. I thought that when I added the Warn hubs, my 4wd problems were over. I got stuck today because I couldn't shift into 4wd. I turn the switch and nothing happens. No dash light, no transfer case switching, nothing. Luckily a Ford buddy showed up to tow me before one of the Chebby guys. Any thoughts anyone??
Old Jun 9, 2006 | 01:36 PM
Medic 66's Avatar
Medic 66
Are these manual warn hubs? I was unaware Aftermaket Warns could be engaged with the ESOF switch.
Did they not work manually either?
Old Jun 9, 2006 | 02:23 PM
dmueller71's Avatar
dmueller71
yes, the hubs were locked, the switch didn't shift the transfer case
Old Jun 9, 2006 | 02:28 PM
PSNut's Avatar
PSNut
Sounds like an eletrical problem. Blown fuse? Bad relay?
Nut
Old Jun 9, 2006 | 04:41 PM
dmueller71's Avatar
dmueller71
Thanks for the help. After reading a few more threads, I checked the plugs on the transfer case. Apparently my local transmission "specialist" didn't plug one of them in all the way and it would only work once in a while. Thanks again everybody.
