Mr. G's Enterprises can help with the dash. They are at www.mrgusa.com If you are looking for the gauges themselves, I might have a few left.I need to check to see what I have left.
Kevin,I just purchased and installed a headliner from JCWhitney in my 71 F-100 4x4 .I bought the headliner with the center console and 4 built in speakers, it fit perfect and sounds better than any door speakers I have had, could sound better with aftermarket speakers if you want more.If you go with this headliner be sure to cut the back mounting screws, if you don't they will poke thru the top of your truck .Good luck and have fun .
"bowties in the rearview mirror"
I didn't see a headliner there but I got the carpet and dash cover. The carpet was only up to the seat and 80.00. Total was 127.00. I saw similar prices at all sites, so the cheap short carpet won. I would have shopped here but I was cheap. I got less of a quantity for about the same rate. Next time I buy here.
BTW Nod, I can't find the liner.
Thanks again folks; I trully apreciate this site a lot more than jeepsunlimited. You are down to earth.
Kevin, the headliner # I bought for my 71 F-100 4x4 standard cab is #78as7738nf.If you go online to JCW punch in your truck year then go to headliners, thats where I found it. Good luck.
O.K Nod, you did it now! I was happy with what I had until this. Now I might have to spend 209 more. And at no shipping charge as well. well I'll definitely consider it.
I don't know the policy on addresses- so delete if chosen to. jcwhitney.com/item.jhtml?ITEMID=30734&MEDIACODE=AS
Sorry 72-Ford, I can't do a picture right now. Best I can tell you is to look in a JCW Catalog, what I got was a little different than the picture in their catalog .The catalog shows a raised panel look similar to a raised panel door,but what was sent was a tuck and roll look with the design lines going from front to back continuos which I personally like. Hope this helps.
