Aerostar Ford Aerostar
Rear diff cover
Old Jun 8, 2006 | 08:37 PM
99f350sd's Avatar
99f350sd
Rear diff cover
The book says if you remove it you must replace it and the bolts. Sounds like a bunch of crud to me. What do you guy's think.
Dick
Old Jun 8, 2006 | 10:03 PM
FordBoypete's Avatar
FordBoypete
Thumbs up
Dick,
I've had mine off a couple times in 225K Miles, it's just a plastic cover. I cleanly bead it with black RTV, let the RTV cure until it's almost set, then bolt it back in place. Same bolts same cover, different fluid & RTV. I use black so people don't see red or blue and start asking a lot of questions about my differentials A4WDs have 2 of 'em.
DON'T PUT RTV UP IN PLACE UNTIL IT"S SET ENOUGH SO PIECES DON"T FALL INTO THE REAR END.
FBp
Old Jun 8, 2006 | 10:05 PM
copper_90680's Avatar
copper_90680
Originally Posted by FordBoypete
Dick,
[/B]FBp[/B]
Same here. Have 2 Aerostars and have reused the old covers over and over.
Old Jun 8, 2006 | 10:13 PM
99f350sd's Avatar
99f350sd
Thats what I thought ...Thanks
Dick
Old Jun 9, 2006 | 02:02 PM
Torsen Rick's Avatar
Torsen Rick
I'd bet they suggested replacing the cover because it is plastic. It may not be as forgiving to bolting and rebolting down. Maybe they got brittle and cracked when removed over time or something. I think, though, as long as there are no obvious cracks, holes or gouges in it, then it'll be fine...
Old Jun 9, 2006 | 03:03 PM
copper_90680
But isn't it why God invented RTV?
Old Jun 9, 2006 | 08:45 PM
FordBoypete
Red face
I will tell ya what on rod & Cyl head bolts, REPLACE THEM like the OEM Manual says !
They stretch out 1st time they're torqued and heated to normal op-temp, then next time they just stretch too much. Thus in time they result in uneven torque & pressure and things fail. Heads warp, rods stretch/ elongate or let loose through the block etc.
Don't ask how I know that. . . .
FBp
Old Jun 12, 2006 | 07:41 AM
Torsen Rick
Yes, but diff cover bolts are not torque-to-yield. They actually don't torqued much at all, otherwise the sealant would squish out... So, I can't think of a good reason to replace them unless they're damaged.
Old Jun 12, 2006 | 10:46 AM
FordBoypete
Smile
I do it by letting the RTV cure a bit, so it will form but not squish out and I use the used bolts as I said up front on this thread.
I was making the point above, that "hard torqued" bolts & fasteners these days, or lately it would seem, fatigue after their 1st use, even when stage torqued and then re-checked after use. . . . "they jest don't make'em like they used to."
But I believe we all agree that's not relevant with differential case covers for standard application usage. . . . .
FBp
Old Jun 14, 2006 | 07:50 PM
99f350sd's Avatar
99f350sd
Well its back together and all is fine. I did rear brakes and changed the pinion or spider gears cause someone had two different size tires on the rear. They were the same size but one was 1.5" circ diff. Pinion shaft wear was the result..
Dick
Old Mar 1, 2015 | 01:37 PM
96Aerostar's Avatar
96Aerostar
I was surprised to see that my 96 AWD rear end, traction lok, has a plastic cover.
When I change out the synthetic fluid next time, I will probably replace it with a metal one for better cooling, plus replace the filler plug with a magnetic one. I just did fresh synthetic fluid gasket and blue silicone. When I asked @ Napa they said there was no listing for the front Dana gasket and just use Blue Silicone.
Front is next with synthetic AFT Mercon, Rear I run High Performance 75-90 GL 5 with anti slip additive added, used it in my other Traction Lok just fine, Royal Purple.
Old Mar 1, 2015 | 08:53 PM
96_4wdr's Avatar
96_4wdr
Dana spec'd all the 28s, IFS and solids, for 75w90 GL-5 hypoid gear set lube. Far better gear face loading protection. It was one of Ferd's not better ideas shoving their Mercon in them to increase mpg to meet CAFE.
Run a full real synthetic PAO/ester based 75w90 since the Aero front 28 is so shielded from cooling air flow and has such small case capacity. Seals, bearings and gears will outlast the van then.
Critical to not use the thin to lose ATF if towing, the 28 will get hotter than a firecracker in summer heat.
Put in a drain bolt while you have the front diff cover off, you'll see why after the first time. Change often
Old Mar 2, 2015 | 03:21 AM
xlt4wd90's Avatar
xlt4wd90
When I filled the front D28 axle with Mobil 1 75W gear lube, it would gush out of the vent tube after every drive. I refill again to the fill hole on the side of the case, and again, it would gush out. I suspect it's overheating enough to expand out the tube so much shoots into the vent hose, all the way up its full length and spill out, making a mess. When I started to refill with ATF, it stopped doing that.
Old Mar 2, 2015 | 07:48 PM
93nighthawk's Avatar
93nighthawk
TSB 98-23-3
Front drive axle fluid may leak out of the vent under some driving modes on some vehicles. This may be caused by the design of the vent.
ACTION:
Install a revised front axle cover assembly which incorporates a baffled vent and plug the original vent. The service procedure is detailed in the Instruction Sheet included in the Axle Cover and Baffle Kit.
The Axle Cover and Baffle Kit (F79Z-4033-AA) includes the following:
  • One (1) Baffled Cover
  • One (1) Vent Hose
  • One (1) Plug (for original vent)
  • One (1) Instruction Sheet
PART NUMBER PART NAME F79Z-4033-AA Axle Cover And Baffle Kit
The part is obsolete and there are none out there.
Old Mar 3, 2015 | 01:15 AM
xlt4wd90's Avatar
xlt4wd90
Thanks Nighthawk. Is that a replacement for the rear (front) cover of the axle housing? Is that where they put the new vent? I remember trying to pull off the cover when I was changing the lube, but gave up after a while because it was glued so tightly to the housing.
I will note that the axle didn't spew before I changed out the original ATF to 75w90 gear lube. And the leakage occurred during my normal drives, as in going to/from the same places as before, with no terrain changes.
