I better not use it for chapped lips or diaper rash thenI assume you can put some inside the plug boot? A little hint for changing spark plugs,I cut the end of a old plug wire off,then put the new plug in the cut off boot to start threading the plug in. It works nice,so you seat it properly,not stripping it out.
Quick question on the topic of the boots. Has anyone used the Standard Ignition replacement boots? If so, is SPP39 the right number and does it come with the sping?
It worked. I used the di-electric grease and it worked like a charm. Truck is running strong like it was when it was bought, and no more farts. Thanks, you guys were right. Thanks again.
