1978 - 1996 Big Bronco
E7ta-9k044-aa
Old Jun 7, 2006 | 11:03 AM
Tech-man's Avatar
Tech-man
E7ta-9k044-aa
Anyone have one of these they are not using and would sell? Ford calls it a fuel delivery module, it goes on the driver's side frame rail, has two lines going in and out. Mine is cracked and leaking fuel. Ford no longer makes it. Can someone help?
Old Jun 7, 2006 | 11:18 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
crosses over to a FOTZ 9K044-A FTE $26.34
It is still available!
I can sell you one!!!
Ed
Old Jun 7, 2006 | 11:27 AM
Tech-man's Avatar
Tech-man
Cool
Send me the info, I would like to see a picture if I could. I didn't think I was getting accurate info from my local Ford dealer.........
Old Jun 7, 2006 | 11:47 AM
Parts Guy Wyatt
Former Vendor
Here is a pic, what other info do you need?
Ed
Old Jun 7, 2006 | 04:24 PM
Tech-man's Avatar
Tech-man
That's all, when I went back to work I went to your website and found out what I wanted to know. Do you like CPD for parts lookup? When I was a parts mgr, we used Microcat for parts lookup and it had places where you had to fill in the blanks. CPD looks very informative.
Old Jun 7, 2006 | 05:05 PM
Parts Guy Wyatt
Former Vendor
I like microcat better, but This is what I got to work with here so I'm cool with it.
send me a order if you want me to get the part for you.
Ed
Old Oct 20, 2019 | 07:04 PM
ueww40's Avatar
ueww40
I have a 1988 Escaper Class C RV on a Ford E350 chassis with a 7.5 ltr engine and I needed to replace the inline fuel pump. Between the fuel tank and the inline high pressure fuel pump is this black plastic unit with 4 fuels lines on it (I guess 2 going in and 2 going out) that is mounted to the driver's side frame rail. There is nothing wrong with this original unit (no cracks, no leaks) but I understand that this OEM unit is no longer available but has been replaced with part number FOTZ 9K044-A FTE and it all has something to do with a fuel delivery or reserve system (or something like this). Anyway, when I unscrewed the can I expected to find a filter element inside but to my surprise it was empty. Can anybody explain to me what this unit is supposed to do and should it contain a strainer or fuel filter. If yes, does anybody know the part number for this strainer or filter. Without a filter element in there the high pressure fuel pump down the line really has no protection. However there is a proper fuel filter installed in line after the fuel pump, which will protect the injectors, but the way my set up is the fuel pump is not so lucky. That's probably why it froze up in the first place. So far I am utterly confused. Please help with some good info! - Thanks
Will Rhodes
Sep 26, 2019 07:15 AM
nathanr561
Aug 3, 2019 05:18 PM
GreatNorthWoods
1947 and Older Ford Trucks
Dec 14, 2018 08:09 AM
Countryboi
Mar 16, 2016 10:53 PM
southern-okie
May 20, 2015 09:42 PM
