</TD><TD class=titlePadding width="100%">KENWOOD P-NAV6019 DDX-6019 + KNA-G510 DVD NAVIGATION
</TD></TR></TBODY></TABLE>
i have a 2004 ford f150 lariat supercrew and was wondering if anyone had this setup, and if the steering wheel controls will work with this setup, any comments will help. thank you
I do not have that set up but I was looking through Crutchfield and found a spot where they aftermarket adapters for steering wheel controls. I Dont know if they work or not but The one thing about crutchfield is that even though their prices arent the cheapest...they usually do not sell junk.
I have the kenwood navigation and like it. It does a pretty good job of getting where you want to go. Check out this site to make your steering wheel controls work http://www.pac-audio.com/default.asp
also does this nav unit let you put addresses in it while moving or do you have to pull over, and can it be fixed to watch dvds while moving..
