loose wiper?
Old Jun 7, 2006 | 08:33 AM
Terran's Avatar
Terran
loose wiper?
My passenger side windshield wiper is really loose. So it makes it practicly impossible to operate the wipers. How do i tighted it back down so it doesn't have all that play from side to side?
Old Jun 7, 2006 | 08:52 AM
Craigster1's Avatar
Craigster1
If the wiper arm is tight where it mounts on the splined shaft coming out of the top of the cowl, then the problem is with the linkage or the spindle that the shaft turns in, either way it is a bit of a project.
Old Jun 7, 2006 | 09:19 AM
73Custom's Avatar
73Custom
Craigs right. Check to see if the wiper arm is tight to the shaft that comes through the cowl. Wiggle the arm back and forth and note if the shaft moves too. If it seems tight, then the problem is the linkages under the dash. The are accessed behind the guage cluster and radio. A little tough to work on - no space.
Old Jun 7, 2006 | 11:15 AM
Terran's Avatar
Terran
It doesn't pull in or out, just side to side. The problem had been getting progressivly worse before i parked it a few months ago, and i really need to fix it before i drive it again. What does it actually take to fix it, are there any pictures or diagrams for it?
Old Jun 7, 2006 | 12:35 PM
Mil1ion's Avatar
Mil1ion
So basically this is just one wiper that has slop in it?
Does it appear to be slop from the splined gear on the outside or feel it's from the inside ?
There is an illustration but it doesn't really show much.
I'll see of I can find it for you.
You will need to pull the top of the dash off to get to it if that needs replacing.
Old Jun 7, 2006 | 03:23 PM
Terran's Avatar
Terran
It's loose from the inside, i worked my hand up there (i have long arms) and i can feel a loose, 'wing nut' type object up there that i can sorta turn, then i can also feel the arm from wipers.
Old Jun 8, 2006 | 10:47 AM
Terran's Avatar
Terran
Anybody know what i can do to fix this?
Old Jun 8, 2006 | 01:57 PM
Mil1ion's Avatar
Mil1ion
Old Jun 8, 2006 | 02:05 PM
Terran's Avatar
Terran
so i need a new arm/shaft pivot?
Old Jun 8, 2006 | 04:50 PM
highboy1975's Avatar
highboy1975
i have a good one sitting around here somewhere. pm me if you want it.
Old Jun 29, 2006 | 08:36 AM
Terran's Avatar
Terran
Would this be the problem? What would cause somthing like that to happen?
Old Jun 29, 2006 | 09:30 AM
Craigster1's Avatar
Craigster1
Hard to tell from the pic but is that the perch or bracket that holds the pivot arm shaft threw the cowl?
It looks like it is broken, if so that would be a big problem. Iv never seen that happen but the cause could be loose linkage, a rusted/frozen pivot shaft, tree branch smack while 4X’ing or that wiper that may have stuck to the windshield during a freeze and when the wipers were turned on……. ”bam”. Whatever happened it looks like replacement is necessary.
While you are in there it would be a good time to check out the rest of the wiper system and anything else under or in the dash.
Old Jun 29, 2006 | 09:34 AM
77fordguy's Avatar
77fordguy
cheap pot metal and years of use?
Mine broke last year on the passenger side. The arm fell off on the wiper side and was still attached to the motor. I called up Jeff's Bronco Graveyard and had another arm in a few days. The replacement was pretty easy. It only took about 1 hour from start to finish.
I removed the glovebox, radio, and ash tray. With a little bit of reaching around, I got to everything pretty easy.
Old Jun 29, 2006 | 09:39 AM
Terran's Avatar
Terran
Yeah, thank god for cell phone cameras, i could not, for the life of me, figure out why exactly it felt so strange.
Powerstroke-7.3
Dec 22, 2012 04:56 PM
rob1994AerostarAWD
Aerostar
Dec 25, 2008 08:33 AM
SDTruckMan
2004 - 2008 F150
Mar 15, 2008 12:31 AM
mantta
May 21, 2007 10:42 AM
