engine
Old Dec 20, 2001 | 02:45 PM
odie186's Avatar
odie186
engine
I have a 352 engine.How solid is this engine?Are there any major problems that ocur with it?What about gas,is it a gas-hog?It is hooked up to a c-6 trans.Any info will help.:-X12
Old Dec 20, 2001 | 03:01 PM
gracie's Avatar
gracie
Post engine
I had a 1970 F250 with a 352 out of a 63 station wagon that had been used in a Demo Derby. Who knows how many mile it had on it? I hauled tons and tons of gravel in that truck when I built my home. (the record was an even 3 tons on one load) The engine never wimpered. If I got it stuck I would redline it getting it out. That was 5 yrs ago and I still see the truck running around town. I don't think you could destroy that motor if you tried.
Old Dec 21, 2001 | 06:21 PM
RangerBill's Avatar
RangerBill
engine
The 352, like all of the FE series engines, is tough as nails. Makes decent HP for its era/application, better torque, and will run forever with a minimal amount of maintenance.
It's no hot-rod, but if you're looking for a good, solid engine that will do all you ask of it, the 352 is a good one to have.
Old Dec 22, 2001 | 11:48 AM
tamwill's Avatar
tamwill
engine
I hada 352 in my '65 and it was a hot rod. The only thing I did to it was to put a new Holley 2 bbl. and a new air cleaner. I think it had 4.11 gears, so that helps. I had it for two years with nary a problem.
-Bill-
Old Jan 3, 2002 | 12:42 AM
Cowboy_351's Avatar
Cowboy_351
engine
Old Jan 3, 2002 | 05:41 PM
ford racer 02's Avatar
ford racer 02
engine
What if the engine has sat for awhile, it isn't locked up or anything but it has sat for awhile, i am planning on putting new main seals in it thanks for the other info, you ford guys are great!!!
:-staun
68cabby
Aug 17, 2012 10:48 PM
JSavage24
Feb 10, 2011 06:36 AM
shelbyville
1983 - 2012 Ranger & B-Series
19
Oct 26, 2010 01:06 AM
myEXisFAT
Jan 26, 2007 11:07 PM
