engine tranny swap
Old Jan 4, 2002 | 10:53 PM
69er's Avatar
69er
engine tranny swap
Is it possible to put a 351w and c6 out of 1979 econoline 350
into a 69 f100 with a 390/c6
Old Jan 4, 2002 | 11:21 PM
LxMan1's Avatar
LxMan1
engine tranny swap
Yes, you will need to find 302 frame mounts for your year of truck. I believe that the motormounts on the van will work fine. You should be able to reuse your tranny crossmember. Most anything that you would need would be the same as a 302 truck from 67 to 72. The 351W is basically the same as a 302 except it is 1" wider and 1" taller.
Old Jan 5, 2002 | 03:26 PM
69er's Avatar
69er
engine tranny swap
Thank you for the info 69er
Old Jan 6, 2002 | 02:49 PM
motorhead's Avatar
motorhead
engine tranny swap
tired iron
15
Feb 3, 2006 03:09 AM
shrike
May 12, 2004 12:46 PM
jefhrt
Engine Swaps
Apr 30, 2004 07:39 PM
69crewcab
Nov 12, 2002 11:31 AM
nojeffgordon
Oct 18, 2000 03:13 PM
