leakage
Old Jun 6, 2006 | 11:47 AM
slaymet69's Avatar
slaymet69
Exclamation leakage
i have a 1985 f250 turbo deisel supercab superduty and i was wondering is it normal for my truck to drip water from under the engine after i drive it because i hear that deisel trucks make lots of water or somesort?
Old Jun 6, 2006 | 04:32 PM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
Are you sure it is not condensation from the AC?
Old Jun 8, 2006 | 01:02 AM
slaymet69's Avatar
slaymet69
im not sure it might be since it comes from under neath the ac ,but it is alot of water , more than what i would think of as condensation. like after i run the car i park it and it is a steady drip 1 drip every 1-2 seconds for about 10 minutes. also it happens when i dont have the ac running.?
Old Jun 8, 2006 | 04:45 AM
Sycostang67's Avatar
Sycostang67
The A/C is usually working whether you have it on or not. Net time you are done driving pop the hood and watch for it. You can easily tell if the A/C evaporator is sweating(beer can effect). It could be a bad heater hose connection at the firewall as well.
Old Jun 8, 2006 | 11:43 AM
big hoss 29's Avatar
big hoss 29
Have you checked the water level in the radiator to see if it needs to be re-filled? That should tell you if it's from the engine or not.
