I have a 1995 Crew Cab, dose anyone know how to take the rear door window motor out ? the motor just clicks when I push the up or down button so Iam thinking that the motor or the brushes are bad.
Hey and welcome to ford trucks!!
you would have to pull of the pannel on the inside. there is crews all around it, take htem out and then you have to pull it off. then you shoudl be able to see the motor and should be simple to take out when you have the door pannel off.
good luck
Mitch
My rear door window quit working too. It turned out to be the gears on the lift arm was stripped out. Had a hard time finding the part.
A couple screws and some push-in plastic clips will pop the door panel off. Get a door panel removal tool so you don't break the clips.
The window motor and lift arm assy are riveted to the door, the rivets need to be drilled out. You can use 1/4 bolts instead of rivets to get it back in.
