1978 - 1996 Big Bronco
302 to 300
Old Jun 5, 2006 | 08:02 PM
muscletruck7379's Avatar
muscletruck7379
302 to 300
i just got a 300 six and decided to drop it into my bronco since my 351 isn't done yet. so what will i need to successfully complete the swap, i should have engine mounts, and i need to fab an exhaust anyways,bellhousings and clutch are the same, etc. maybe i can make it to the 4wheeling meet in estes park next month!
Old Jun 5, 2006 | 10:08 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Well, you could, but you would have to scrap the exhaust when the 351 goes in.
I think you have to use a throttle cable from a 300I6 truck.
Old Jun 6, 2006 | 08:22 AM
Johnboy_BoomerSooner's Avatar
Is it a carbed 300? I'm running a motorcraft 2bbl off a 302 on a stock manifold with an adapter. It uses the same throttle cable as the 1bbl carb did, I just had to fab a new cable mount to because the linkage is turned 90 degrees from the 1bbl carb. 2bbl motorcraft and a duraspark II swap and the I-6 will really come to life. Just be sure you get it bolted in there good... the biggest problem I have with mine is that it chews up trans brackets and drivers side motor mounts. The motor torques and twists a lot, and it's came loose in there a couple of times.
85Blondie
Aug 28, 2013 01:16 PM
toolebox1
13
Jan 4, 2007 01:51 PM
dropper
Oct 13, 2006 10:59 PM
NotbyChoiceFord
Apr 30, 2006 01:15 AM
Southernguy101
Exhaust Systems
Mar 5, 2005 04:24 PM
