I've seen several of these on Ebay for cheap and from the feedback they look like they work but on the Durango forum we were told to stay away from them. Any feedback on whether they work in the Ranger? Thanx
No...one of those usual BS schemes that regularly pop up. This has been rather discussed on here. It's good for maybe a quarter of a horse on a ideal day.
On not so ideal days, it can realllllly screw with your PCM since it's telling it it's sixty degrees when it's really not. Hard starts in cold or warm weather, poor running performance, bad warming up, etc.
It's garbage. Period. The 20 HP claim is fraudulent. At best, the EEC system will adapt and render it useless. More than likely your gas mileage will suffer because of the changes the EEC system will undertake to try and accomodate for the phony readings.
They are just a 25 cent resistor in a *cute* plastic box that attempts to trick the ECM into thinking that the intake air temp is cooler than it really is. The concept is that the engine will run richer. But as Rock correctly noted, many ECM's will quickly relearn (because the existing sensor has tolerances on it is why there is the relearn) and it will serve no useful purpose (except for phantom HP ).
I acutually bought one a year ago or so becasue is cost me $4 and was worth a shot, BUT I found out that it does just what was explained above.....it basically makes your engine run in open loop.....I will give you mine if you are in AZ and you can try it for yourself!
I tried the old "resistor trick" on the dyno about 4-5 years ago with my former 99 Mustang GT.
In short, it made no difference at all. It didn't trigger a check engine light but it didn't do anything to make any more power either. To be totally honest, given what I've seen in the code of most Ford EECs, the ACT does little more than add or subtract ignition timing. Since the MAF directly measures air mass, there's really little need for the ACT reading to determine if more fuel is needed.
Even in older speed density systems the ECT is the primary sensor for calculating air mass since it is assumed that the engine will heat the incoming air charge to a degree, thus changing its density.
The thing to remember with most ford fuel injection systems is that you gain power by LEANING the mixture, not making it richer. That is how all the hand held programmers do it. It is rich from the factory for safety margins.
