Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
air tool checkout
Old Jun 5, 2006 | 12:26 PM
ford2go's Avatar
ford2go
air tool checkout
I got a couple of air tools ( ratchet and a gun) when my father in law moved to assisted living. They're IR, so they are basically of good quality, but they've been well used.
Any thoughts on some things that I should check on them? My compressor should be up to driving them, and they do spin. I suspect that they may need some attention, but I'd like to know if they're too far gone to be worth it.
Thanks,
ford2go
Old Jun 5, 2006 | 06:43 PM
fixnair's Avatar
fixnair
I'd squirt a little oil in the inlet and apply some air. If they run without vibrating I'd go ahead and try to torque a fastener down and then take a wrench and see how tight the impact wrench made it.
Be careful with the ratchet because it will try to twist you once the bolt is tight. If you dont have room to turn it will run your hand into whatever is in the way. It can hurt. Also, the reversing mechanism is in the back head. If you run a nut up a long fastener and the back of the ratchet hits a casting, how do you change directions to get the wrench off again.
Don't use pressure higher than 125 PSIG either.
Good Luck
Old Jun 5, 2006 | 07:01 PM
frederic's Avatar
frederic
With a very small screwdriver and a small wooden mallet
Old Jun 5, 2006 | 08:09 PM
fixnair's Avatar
fixnair
I see you have been there and done that too.
Wyowanderer
Apr 29, 2014 05:33 PM
kadrocker
Dec 5, 2009 09:56 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jun 9, 2007 05:23 PM
Fullcrew7.3
18
Apr 5, 2007 12:17 PM
DarkFX4
2004 - 2008 F150
Sep 29, 2004 10:22 PM
