Faced with a tough decision...
PROS
1) It's lighter and stronger
2) It's cheaper? My research so far says it would cost between $500 and $900 in steel to do this right. I need to do more digging to see how much it would cost to repair my stock frame. Check out my gallery titled "carnage". There's a pic in there that clearly shows how bad my frame is twisted. It's also bowed up over the rear wheels. At one time, this truck has been rear-ended HARD! Anyone who's ever repaired a frame, please gimme your 2 cents!
3) It would be easier to install the '75 Monte Carlo IFS. Wouldn't it? If I'm doing the frame from scratch you'd think it would be easier to build it around this suspension. I'm planning on doing pwr steering, front disc brakes, and a Ford 460. Any input here would be greatly appreciated.
Cons
1) There's been lots of talk lately about stock guys and darksiders, and greysiders. I'm not really concerned about labels. I want a cool truck that looks good and is fun to drive. To me, a truck without IFS and pwr steering is not fun to drive! I do, however want to keep it as Ford as possible. I mean, if I'm going to do a custom frame, I might as well scrap the entire truck and buy everything new...just spend megabucks and go fiberglass with everything. In that case, why did I buy this truck in the first place? It never occurred to me that you could just build a truck with all new parts. I don't want to do that, but it is possible. One of the things that got me interested in old trucks is the history. What's the point of driving something that "looks" like a '60 if all the major parts are circa 2006?
2) Low rider trucks **** me off! There's nothing that annoys me more than seeing a truck that has to slow down for speed bumps! I like the look of a truck that has been lowered enough to fill up the wheel wells, maybe a bit of a rake. I hear with airbags, the ride height is totally adjustable though. Again, input appreciated.
I'm not on much of a time crunch, although I am anticipating having to move in about 2 years when I get out of the Air Force and move back home to Florida to build my dream house. I would like to have 'er driveable by then. I would appreciate anyone's input! Thanks!
www.lavishlogos.com he can make custom setups like battery hold downs, brackets, etc...may be different than what your looking for, but there certainly is the cool factor with bags. Just my 2 cents.
I wish I had a buddy who made custom frames. However, a time line of 2 years to build a custom frame, suspension, etc, with all the custom fitting of IFS, brakes, cab, and get to a cross-country driver seems a very short to me. I have friends that run a pro hot rod fab shop and do the kind of work you are talking about. They typically take 18 months to 2 years to do a ground up job like that working full-time. A typical after-market custom chassis made for your truck will start around $8000, which gives you an idea of the work involved. We've got guys on this forum that are still working on the chassis after 5-10 years. If you are certain that the 2 years is a fixed time line, I think you should look in a different direction.
Air ride suspension itself has many pros and cons. To say that it is completely adjustable for height is true, but the ride suffers dramatically everywhere but the sweet spot. The ride height has to be optimized by using the proper bag sizes and the suspension only works well at that height. You can slam it lower, but it will be so soft, it bottoms on everything. Or, you can set it up high, and it will ride hard. To me, air ride is very cool, but just for parking it on the ground. You have to set it up for the ride height you want. They ride very nicely when done well and can be sized for any weight distribution, including that heavy 460 of yours.
I really believe that you would be much better off just getting another (straight) 57-60 frame, boxing it and go from there. The frame should run you in the $100 range. Add your IFS, power stuff, air ride (if you want), etc. You'll be good to go, and it is doable in the 2 year time line.
Of course, the custom chassis thing does give you more bragging rights on cruise night, but if the end result rides as well, why bother?
Just my 2 cents...
Now, about your frame. Have you talked to a shop about straightening your frame and the cost of that work? I think youre being VERY optomistic on your steel cost estimate.
A LOT of people are making a LOT of markup on this stuff.
Most of the stuff used for air ride (bags, lines, fittings, solenoides) was designed as industrial or agricultural components.
Shop around and work out what brand and part number of bits you want.
Then go and check out the industrial and agriculture supply places.
A $10 grain elevator damper doesn't mind pretending to be a $80 air spring.....same part from the same factory.
Buy a Harbour Freight or similar 10 ton port-a-power
Buy a sledge hammer
Straighten your own frame and fit new tubular gearbox and engine crossmembers (TCR etc have them)
You will have a straight frame and you will own some cool tools and a big solid fabrication bench.
PS If your mate makes custom frames he probably has the frame table and port-a-power already......if he doesn't he shouldn't be making frames
I understand they are starting to come up with some repair panels (your cab looks to have rust in all the normal places). That would be a real help as the front corners are a bear to repair, and have to be sturdy enough to hold the doors in place.
I repaired mine, but it was ugly. I found a rust free cab and will be using it instead of the repaired one. The rear rust pockets are not structural, but anyone who knows these trucks will be looking for damage there, and as good as you want the rest of the truck you will want that area to be first class too.
The frame is not a problem - they are easy to repair, and boxing them will hold the shape well. The body shop I grew up in had a piece of railroad track that would slide under the car, and, using chains and hydrailic jacks, you could bend a frame anyway you needed.
In addition, frames are not very expensive to buy. I gave $100 for one donor, and a $150 for the other with a rust free cab. I will have the frame exposed tomorrow and will email you some pictures you can use to fix yours.
Too bad we are on different coasts or I would just give you a good frame to start with.
The real problem is the 460 V8 - man that is a horse that will torque everything on the truck. You need to think about boxing the frame and adding lots of brakes and suspension to hold that beast on the road.
I assume you will be wanting to stay with the Ford 9 inch rear, but it will need help, spring wise. People do it so there are special traction devices and spring setups, but they are expensive and require planning.
And, if you use a gm front clip, you will need two different spares.
If that is the damage you are talking about - do not fix it! If you eyeball down the bottom of the rail you should see that the bottom of the bump stop is about even with the bottom of the rail.
If you would like I can send a picture of my frame showing how much it is humped up over the axle.
