If it has a Carburetor it is more than likely that the Fuel Pump Cutoff Relay is not closing.
This could be from no (low) Oil Pressure, Inertia Switch open or a fuse or fuse link.
Here is a diagram of the system.
Thank you I found the fuel pump cutoff switch on the passenger firewall and reset the switch and away we went.
