302 Timing for best performance ???
Old Jun 9, 2006 | 01:00 PM
shooter05's Avatar
shooter05
I haven't, the only knocks I get are when it is time to change the oil. I have this mysterious lifter that starts to knock when its time, then quiets back down when I change it. I have run Valvoline Synthetic in it for about the last 125,000. A mechanic told me that is what has probably kept it going. I still take it on 5 or 6 ,200mile round trips a year. It frequently makes 100 mile round trips 5 or 6 times a month.
Old Jun 9, 2006 | 01:29 PM
Pacerguyel2's Avatar
Pacerguyel2
knock sensors will only adjust so far, but did we ever really find out what the best base timing setting is so far ??
Old Jun 9, 2006 | 02:11 PM
12secondstang's Avatar
12secondstang
It will be different for everyone. Mods and fuel quality can and will affect how your truck will respond to timing adjustments. As I said before, advance your timing until it knocks under load. Then back it off a degree or two. This will be the ideal setting for you. It should fall somewhere between 12 and 16 degrees. If you use a higher octane fuel, it will allow more advance. Only testing yourself will tell. Generally, the more you advance the better your low end grunt.
Old Jun 9, 2006 | 05:12 PM
Fordnorth's Avatar
Fordnorth
Timing
Do you know if you would damage anything, ie the computer if you were to drive with the spud clip (shorting Bar) out?
rlay302
Jun 5, 2016 11:46 PM
Rcurry93
May 14, 2016 11:58 AM
rlay302
1983 - 2012 Ranger & B-Series
May 6, 2016 11:51 PM
fordkid122
Mar 22, 2016 05:24 AM
easyridin
Aug 27, 2015 06:06 AM
