Trying to get an idea what some of the most common problems are with the Bronco II as far as needing replacement parts for. I have a local junkyard that has pretty many B2s and have gotten a few spare parts but don't know what may be the best things to have around in case.
I have gotten brake calipers, front Auto hubs, and several other misc parts.
Someone told me that the transfer case motors (actuator?) are prone to failure. True?
Thanks for any ideas. That's a good spare time way spend a day, I guess.
If you have a 2.9 keep your eye open for cooling system components as the 2.9 has a strong dislike for heat also as mentioned above a set of heads would be handy to have since they are prone to failure.
Radiator idea would be to find a double-, or better yet, a TRIPLE-core out of an Explorer, Ranger, Navajo, or similar. If you find one, though, I would suggest either swapping tanks from your original to the replacement or having it done by a shop... although people have claimed to have used Explorer or flex hoses and made it work.
