Hi Folks I'm new to this Board and I have a few problems with my Exploer a nd I cant afford to go to a garage to have it checked. because of medical problem ( High Cost of Medications). So any help would be grateful
1991 ford explorer, I keep blowing transmissions, i don't think the cooling system for the trany is working, how can I test it?
1991 ford explore.the problem i'am having is when i need to add trans fld. it seems like it drains into oil pan cause when i check the oil level its like two qt.s over and yes i know where to add these fluids in case you are wondering.do i need to change transmission filter
Thanks
In your debt
Sick in Bed
Sjivey<!-- Message body -->
what is the diagnosed reason for the "blown tensmissions"?
why do you need to add fluid?
There is no pysical connection between the engine oil pan and the transmission fluid system, if you are losing fluid it is either due to a physical leak or a bad modulator valve.
If we can have the answers to the Q's we will be able to start assisting you.
