Code P1443
Old Jun 3, 2006 | 01:36 PM
stirfrysteve's Avatar
stirfrysteve
Code P1443
B4000 LE 1995 5-Spd Manual 2WD
Emissions system.
Any Ideas what this is and solutions?
Thanks.
Old Jun 3, 2006 | 05:54 PM
pawpaw's Avatar
pawpaw
P01443=Small or no purge flow condition.
Check your gas cap & make sure it's tight & it's gasket is good.
Check the vacuum lines at the vapor recovery tank to engine, for cracks, breaks, or loose connections, as the vintage of your ride would put those rubber hoses high on a suspect list.
Let us know what you find.
Old Jun 4, 2006 | 06:28 PM
Rockledge's Avatar
Rockledge
https://www.ford-trucks.com/forums/s...hreadid=152825
Old Jun 7, 2006 | 02:07 PM
stirfrysteve
Hoses are fine. Filled the gas tank(ouch) and reset the code memory.
No return of code. I suspect with just keeping 1/4 or less of a tankful of gas is causing more fumes then normal?
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
