Rear Main Seal
Old Jun 3, 2006 | 10:51 AM
eskew11's Avatar
eskew11
Cool Rear Main Seal
1992, 150, 351 155,000. I had the rear main seal changed in Jan 05,first one leaked within two weeks,mechanic put in another one along with some kind of sleeve. Didn't notice anything until a couple of months ago that it looks like it is starting to leak again.I have only put 3,000 miles on the truck since it was changed.The Mechanic told me because of the high miles and there being to much play in the bearings that that is what is wearing out the seal. What do you guys think?
Old Jun 3, 2006 | 01:06 PM
petes79f150's Avatar
petes79f150
Excessive crankshaft end-play, a sign of a worn thrust bearing, can indeed cause wear of the seal. Also, improper installation of the last seal can too. Did he check crank end-play? If not, and your oil pressure is fine, how does he know your bearings are worn? I'm curious about the "sleeve". Was it supposed to be a cure for worn rear main bearings?
Old Jun 3, 2006 | 05:19 PM
eskew11's Avatar
eskew11
Dont no if he checked or not ,but he said it had play.He said the sleeve was put in because there was a groove were the seal went and this is to eliminate that.
Old Jun 3, 2006 | 06:12 PM
petes79f150
Sorry, I still don't get it. The seal goes IN a groove. Now, he may be talking about something else entirely, but I've personally never had to have a sleeve installed there. Now, he must have checked the endplay or he's got really sharp eyes because it's generally in the .004 to .008 in. zone. That's thousandths of an inch. A bad number would be anything over .012 in. If he can "wiggle" it around without measuring, you've definitely got bearing problems. How's your oil pressure? -Pete P.S. Hate to ask, but do you trust your mechanic?
Old Jun 3, 2006 | 06:49 PM
Clubwagon's Avatar
Clubwagon
The sleeve is a repair item that is commonly used to fix a rear crank seal that has worn a groove in the surface of the crankshaft where the lip of the seal rides. Just changing the seal doesn't work because the new seal leaks where the grove is. The sleeve is just a thin steel band that slides over the end of the crankshaft so the seal has a new surface to ride on.
A more knowledgeable mechanic would have not driven the new seal in so deep so that it road a little further out on the crank so it would miss the grove and have a nice smooth surface to seal against.
Regardless, if the thrust bearing is worn and the crankshaft is moving fore/aft then nothing will fix the rear seal leak. You do need to have the crank's thrust movement checked carefully with a dial indicator. If its out of spec you may be able to just change the main bearings and solve the problem. Replace the oil pump while you are in there.
Steve
'95 Clubwagon XLT
Old Jun 3, 2006 | 06:59 PM
petes79f150
Ahhh! Learn something new every day. Makes sense now, just never had to have that done-just lucky I guess.
Old Jun 4, 2006 | 09:21 AM
Tech-man's Avatar
Tech-man
If the mechanic didn't put some kind of sealer on the flywheel/flexplate bolts before he put them back in, you will have a leak in that same area, but might not be the seal itself. Oil will travel through the threads of the bolts and leak in the bellhousing area.
Old Jun 4, 2006 | 09:43 AM
Clubwagon's Avatar
Clubwagon
I am pretty sure those are blind holes and do not go through to the oil passages inside the crankshaft. We changed hundreds, if not thousands of flywheels at my shop and I don't ever remember putting sealer on flywheel bolts and we had no trouble with leaks.
Steve
'95 Clubwagon XLT
Old Jun 4, 2006 | 02:05 PM
ken75ranger's Avatar
ken75ranger
Steve
'95 Clubwagon XLT
They are blind holes but you should use thread locker on the bolts.
Old Jun 4, 2006 | 02:17 PM
Tech-man's Avatar
Tech-man
Red face
Whoops, my mistake....O.E. 5.0 cranks have the holes drilled all the way through the rear flange, 5.8's do not. Thread locker acts as a sealant just the same. Teflon, rtv silicone work also to stop the oil from getting through.
