2000 Exp Brake Issue
Old Jun 3, 2006 | 09:35 AM
MBillings's Avatar
MBillings
Smile 2000 Exp Brake Issue
First time poster.. be easy. First, thanks to all that post, I have used the FTE site and it has saved me many $$ and much stress.
On to the issue. I have a 2000 Exp 2wd. The pads have been replaced, system bled and rotors turned. The issue I have is that about 60% of the time, when easing to a stop the peddle gets "hard" near the lower end of the cycle, then I can feel/hear what sounds like a pump. You can feel it in the peddle. The vehicle stops, but with the strange feelings... it makes me wonder. Not crazy about having the wife and kids in it while it is doing that.... Fluid level is fine. I did the standard 30 second pedal test.... no noticable drop in the pedal. I pressed the peddle and cranked the vehicle.... normal slight drop in the pedal...
I would be very grateful for any advice.
Thanks in advance!
Old Jun 3, 2006 | 04:26 PM
EagleDakota's Avatar
EagleDakota
Sounds to me like you need to have your anti-lock brake module checked.
Old Jun 3, 2006 | 05:13 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome MB, to Ford Truck Enthusiasts!
See you on the boards. ….
