Body Bwap
Old Jan 29, 2002 | 12:39 PM
xingfool's Avatar
xingfool
Body Bwap
I have a 1971 Ford Highboy 4x4 and a 1978 Ford F150 2WD.
The 71 body is rusted bad, but my 78 is in good shape.
Will the 78 body fit the 71 frame.
THANKS
Old Jan 29, 2002 | 02:38 PM
mk's Avatar
mk
Body Bwap
The cab on 73-up trucks is two inches longer but I think the mounts are the same. There are frame width issues on the box but you should be able to figure something out.
Old Jan 29, 2002 | 06:26 PM
ford429cu's Avatar
ford429cu
Body Bwap
>THANKS
The 78 body will fit the 71 frame. The cab mounts in the front are in the same spot, but the rears are different. On the 71 the mounts are on the outside of the frame while on the 78 the mounts are on the cross member. The radiator support will bolt right on. The front bumper from the 78 will work but you will need to take the brackets off of the 71. The bed will fit but not bolt right on, you will need to drill new holes. The wheel base on the 71 is 131" and the 78 if its a long bed is 133" so your rear tire will not be centered in the wheel well. It is hard to see it being only 2" off center. While doing this swap use all the wireing from the 78 just to make things easier. I did this swap with a 79 body onto a 72 F250 4x4 frame. If your 78 is an F250 4x4 i'd conver the power sterring over and put the 78 front end in the 71 if the gears match and in good shape. Let us know if you have any other questions. Good luck.
Jeff
Old Jan 29, 2002 | 10:07 PM
Mil1ion's Avatar
Mil1ion
Body Bwap
Aaron-71
Jul 14, 2011 08:34 PM
larry57
New Member Introductions
May 13, 2006 10:12 PM
Enthused'71f1004x4
Jun 24, 2004 10:14 AM
comet
May 3, 2004 11:10 AM
rjs
1978 - 1996 Big Bronco
May 1, 2002 11:48 AM
