Glovebox Repair
Old Jun 2, 2006 | 11:34 PM
FERacing66's Avatar
FERacing66
Question Glovebox Repair
Hello again,
I have a question for a knowledgeable expert. Recently my glovebox door failed and came open, before it had a lot of spring pressure and worked flawlessley. It now justs hangs open and passengers legs hit it. I am wondering how this glovebox works, so I can fix it.
Thanks,
FERacing66
Old Jun 3, 2006 | 11:50 AM
66beater's Avatar
66beater
There are 2 springs, one on either side. they are easy to see from undernieth, but I believe the inside of the glove box has to be removed to install the springs. I have a new set of springs from LMC that have yet to be installed, mine does the same thing if I hit the gas too hard.
Old Jun 4, 2006 | 08:12 PM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS
The thing that bothers me about these glov boxes, or mine anyway is the box its self are made of cardboard. I think I will build one out of metal.
Luckily my springs are still working.
Old Jun 4, 2006 | 09:28 PM
Customcab's Avatar
Customcab
As stated by 66 beater; sounds like either your springs are broken or the spring ends could of either pop out of the anchor holes. But probably/ more likely broke springs. You can purchase springs and even a new glove box from numerous suppliers; as well as new **** and tire pressure decal for them as well now day's.
Mitch
Old Jun 4, 2006 | 10:52 PM
FERacing66's Avatar
FERacing66
Thanks for the info, bought a spring from the hardware store, jammed one end of the spring into the back of the cardboard, the other end onto the glovebox door, works good! Would like to do a proper repair, but more pressing projects get first priority. I also am disappointed with the cardboard, already blew a hole threw mine.
homeschoolin
Nov 14, 2011 07:51 PM
FERacing66
May 3, 2006 06:43 AM
FERacing66
Apr 5, 2005 10:54 AM
FERacing66
Oct 15, 2004 04:20 PM
FERacing66
Feb 21, 2004 12:25 PM
