Pulsating engine
Old Jun 2, 2006 | 07:47 PM
trike1946's Avatar
trike1946
Question Pulsating engine
What causes an engine to pulsate at idle? The rpms go up and down constantly, but even out when moving. It doesn't seem to be a problem now, but I didn't think it was supposed to do it. It is my 96 that is doing it. Thank you for any help.
Old Jun 3, 2006 | 12:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Generally it's an oil system problem. ICP sensor, IPR valve or o-rings, Injectors.
Could also be as simple as needing the oil of fuel filter changed.
Old Jun 3, 2006 | 04:58 PM
trike1946's Avatar
trike1946
Thanks for the reply. Would any of those show up as a code? If not is there a way to check them? I just changed the oil and filter and fuel filter about two weeks ago. It made no difference.
Old Jun 3, 2006 | 10:19 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yes. There are several codes that the ICP sensor can trigger.
Old Jun 4, 2006 | 05:09 AM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Hey Cookie88 are you speaking of the engine oil and the fuel filter? I can understand a clogged fuel filter, but whats engine oil got to do with surging?
Old Jun 4, 2006 | 02:37 PM
1997F-350's Avatar
1997F-350
a hpx helped mine out. it idles perfectly smooth now.
oil has everything to do with the idle.
Old Jun 4, 2006 | 04:04 PM
cookie88's Avatar
cookie88
FTE Emeritus
The injectors are fired by high pressure oil. All sorts of funny little idle/drivability issues can crop up from old tired oil.
Old Jun 4, 2006 | 05:22 PM
Riata_Ag's Avatar
Riata_Ag
What is a hpx?
My '97 has a little lope to her when you first stop and place the tranny into P.
In about 2 seconds the engine smooths out.
maybe I need a hpx..............
the Ford dealer has been changing the oil in this truck prior to my purchase.
I have no idea what brand of oil they use..............maybe I need to go ahead and drain her and give her a taste of some rotella............
totavikid
Apr 24, 2013 01:35 PM
mrpatrick150
13
Apr 4, 2011 12:34 PM
JoeBlow
17
Nov 4, 2005 04:33 PM
Fomoco1546
Aug 28, 2004 08:20 PM
dpoelstra
Electrical Systems/Wiring
Nov 20, 2002 01:48 PM
