Exhaust Temperatures
Old Jun 2, 2006 | 06:13 PM
jkm4874ford's Avatar
jkm4874ford
Was wondering what exhaust temperatures should be at the header flanges. I have about a 150 -200 degree swing between cylinders. This sounds pretty extreme.
Old Jun 2, 2006 | 07:44 PM
petes79f150's Avatar
petes79f150
I would like to have a little more info on your setup. Like, are you running any aftermarket parts and on what engine? Do you know how to read your plugs? How's it running, etc.-Pete
Old Jun 5, 2006 | 08:27 PM
jkm4874ford
The motor is a 306 w/a mild cam and 4 barrel alumn. intake. I am using mustang shorty headers. The plugs never look very bad. My driving is 30 miles down the interstate at 75 mph. I am running a 650 cfm Holley. Thanks
Old Jun 7, 2006 | 11:41 AM
Bdox's Avatar
Bdox
Are those temp readings after a hard run? Or just at idle?
Old Jun 7, 2006 | 06:41 PM
jkm4874ford
After a 25 mile run down the interstate at 75 mph. There will still will still be a good 100 degree swing after a drive around town.
Old Jun 7, 2006 | 09:07 PM
Bdox's Avatar
Bdox
If the engine is running well, I would attribute the temperature difference to some compromises in the header design.
