Holley Carb guru needed.
Old Feb 1, 2002 | 06:03 PM
lee's Avatar
lee
Hi,
I have a Holly LIST-6830 4bbl on my 1970 F-250 4x4 with a 390. I rebuilt this carb and have a problem I can't fix. The carb back fires (burps) at mid throttle only. Shoot a flame a foot high out the carb, scary! If I push the pedal past mid way it runs VERY well. I have checked everything I can think of to fix it. The floats are correct, idle mixture's fine. Cannot find any vacuum leaks. I am sure the problem is in the carb as I borrowed another carb and it runs fine on my truck.
As a side note, I have discovered that I failed to install the Diaphragm check ball in the secondary vacuum canister. What is the purpose of this ball. From the diagram of the carb on the Holley web site this ball looks like it is PREVENTING the vacuum needed to operate the diaphragm. ?? I will install the ball tomorrow but I personaly don't think it will fix my problem.
Thanks in advance for any suggestions,
Lee
Old Feb 2, 2002 | 12:01 AM
1ole4d's Avatar
1ole4d
I'd check your timing just for the heck of it. I remember when I rebuilt my 351 that I had put the dis. back in WAY too far advanced and the truck would shoot flames out the carb. I retarded the timing back to where it was supposed to be and never had a problem with it again. Just something you might want to check.
1978 F-150 flareside. Primitive by todays standards but she was a jaw dropper back then. :-staun
Old Feb 2, 2002 | 08:46 AM
Hottarod's Avatar
Hottarod
Well mid throttle is about when the secondaries start to open so it could be part of the problem. If they are hanging up or flopping open all at once it could cause a temporary lean out and would stumble the motor pretty bad. Timing is usually the culprit for a backfire through the carb though. Its caused by not having enough advance which allows the spark to fire way too late. By then another intake valve is starting to open and you get fire up through the intake and carb. It may be that you have a secondary stumble coupled with the advance not advancing enough or fast enough. If you have had any significant backfires into the carb you will probably need to consider installing a new power valve unless you have the power valve check ball protection.
Old Feb 2, 2002 | 01:48 PM
FozzyNOK's Avatar
FozzyNOK
PapaBearYuma
Mar 5, 2017 10:44 AM
bluestang65
15
Jun 13, 2015 12:04 PM
wyckedcombo17
Aug 15, 2014 06:25 AM
Welder10
Jan 31, 2010 08:25 PM
