FE ford back blocker plates is there a difference?
Old Jun 2, 2006 | 02:53 PM
jk72's Avatar
jk72
I need a back blocker I found some on E-bay but there are many different ones??
I'm putting on a C 6<O></O>
Old Jun 2, 2006 | 10:32 PM
Hypoid's Avatar
Hypoid
Do you mean the shim between the block and tranny? No changes I'm aware of. If I'm wrong about that someone will give the correct info. A bud bought one at the local machine shop/NAPA store (I think).
In any case, here's a bump.
Old Jun 2, 2006 | 11:48 PM
jk72's Avatar
jk72
im looking at buying on an e-bay auction and the seller has 4 difrent ones all look closly the same but have minor difrences????
Old Jun 3, 2006 | 10:26 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
The block plates I've seen either have three holes in them around the cam plug hole or no holes. The plates with the holes are for the hyd lifter galley plugs. The plates without the holes are for a solid lifter block but holes can be drilled if needed to use on a hyd lifter block. i've only had 4 spds so I'm not postive if the C6 plates are different or not. I'm pretty sure they are the same tho....
G.
